Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
Well now that I have been inforned that I have to vent my heads or the motor will emplode sucking all known matter into the remaining black hole, anybody know the recommended fitting size?
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
The size that fits the large diameter German hose.
Brett W |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None ![]() ![]() |
Go to the parts store and get the fittings that screw into a small block Chevy intake for heater hose outlets. They should be something like a 1/2 pipe thread with a 5/8 hose nipple on the other end. Buy a 1/2in pipe tap and screw the fittings into each head.
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
sorry to completly hijack this thread, could somebody tell me where the head venting provisions are located? I don't even know if mine are hooked up...... pics please?
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
if you have them, top of head near the intakes.... search......quite a few threads showing location, how to install if you don't have them....it is not the end of the world if you don't have them, but they can help in the long run |
Rhodes71/914 |
Glacier ![]() ![]() ![]() Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 ![]() |
That seems to be debatable. Here is a link to a thread from today that Aaron posted pics and a discussion about cams going and wifes leaving husbands. pics of vents |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) exagerating my friend (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
Rhodes71/914 |
Yes, yes of course but I thought is was funny. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
The crankcase HAS to be vented because pressure has to be evacuated. Extra pressure kills HP as well as creates oil leakage that would normally not be present.
I vent all the heads on my engines as a standard. If not the heads I vent the valve covers to a large capacity breather box. I have seen 2-3% more power on my dyno with a correctly vented engine. |
bd1308 |
are the provisions for vented heads already there, or do i need to machine something?
Jake Raby |
The boss is there on most heads, just drill and tap it 1/4 NPT at a 45 degree angle and run with it.
Allan |
Got my vents installed in the heads. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Then had to pull the 3-4 head because of the plug issue. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
Attached image(s) ![]() |
Lo-Fi Version | Time is now: 13th June 2024 - 06:23 AM |
