PORSCHE script fastners, Solution for hard rubber |
keely444 |
Jun 2 2015, 05:30 PM
Member Group: Members Posts: 103 Joined: 4-May 15 From: santa cruz Member No.: 18,702 Region Association: None |
I found a set of PORSCHE letters for my engine lid. The letter fastners / grouments are very dry and hard.Any good ideas to rejuvinate those?Any resonable cost options for fastners?
GeorgeRud |
Jun 2 2015, 05:46 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
They are probably still available through Pelican Parts or the dealer. Otherwise some simple push nuts from the local hardware store will fasten them as well, just have to bring one of the letters in to check the size required.
Tom_T |
Jun 2 2015, 06:01 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) They're still available & not too expensive, since they're also used on other P-cars.
Try your local Porsche Dealer or Porsche parts supplier. I know that Rich Bontempi at HPH in Redwood City has some, since I got a set with an NOS set of the engine lid script for my resto. He's fairly close to you & has a huge stash of new, NOS & used 914 parts. Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
GeorgeRud |
Jun 2 2015, 06:11 PM
duplicate post-sorry! |
keely444 |
Jun 2 2015, 08:14 PM
Thanks Guys, I am started to run low on dough. This his car is the only thing that spends faster than my wife. I need 14 of these and when was the last time you got anything under $5 ea. I will check out your sources.
Thanks Again |
Cuda911 |
Jun 2 2015, 08:24 PM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
The fasteners are called "speed nuts." I went to a zillion hardware stores, and all I got was a bunch of confused folks when I asked if they carried 'em, even when I showed them one. So, order them from Pelican, etc., and don't waste your time at hardware stores.
914Next |
Jun 2 2015, 09:31 PM
Senior Member Group: Members Posts: 699 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
I actually did find speed nuts at my local Ace Hardware store. 25 cent each.
914Next |
Jun 2 2015, 09:32 PM
Jonathan Livesay |
Jun 2 2015, 09:42 PM
Senior Member Group: Members Posts: 742 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
If you guys are talking about the kind of rectangular shaped metal ones, they do work, but be aware they do not come off nearly as easily as they go on.
Cuda911 |
Jun 2 2015, 10:23 PM
^^^ Nope. The speed nuts in question have a putty-like goop on the back.
When they get old, however, the putty tends to get dry and crumbly. Attached image(s) |
stugray |
Jun 2 2015, 11:32 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I actually did find speed nuts at my local Ace Hardware store. 25 cent each. Yes! If you guys are talking about the kind of rectangular shaped metal ones, they do work, but be aware they do not come off nearly as easily as they go on. And Yes. Ace has the little rectangular push nuts that will work, and they will damage the pin if you try to remove them by prying or twisting. To get them off you need to grab the tab with a pair of needle nose pliers and twist the tab up. They can be used on the lettering, but I pity the fool who uses them on the grating material at each end of the lid and then ever hopes to get them off again... (IMG:http://www.914world.com/bbs2/uploads_offsite/www.wclco.com-10819-1433309567.1.gif) |
Mark Henry |
Jun 3 2015, 06:46 AM
I use a dab of urethane on the pin, but you have to secure it in place (tape, weight, clamp, etc.) and it takes a day to cure.
bandjoey |
Jun 3 2015, 09:12 AM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Ace has the exact speed nuts hex head but with no rubber back. I cut up a bicycle inner tube for backing. Took in a sample and the guy found them
saigon71 |
Jun 3 2015, 12:52 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I used regular nylon threaded nuts from Lowes to attach my letters. They hold well and I find them easier to remove than the OEM speed nuts. Very cheap too.
pete000 |
Jun 3 2015, 02:13 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
Pelican Parts.
Here ya go...Genuine Porsche are a premium, but I bet they all come from the same supplier. Attached thumbnail(s) |
DblDog |
Jun 3 2015, 02:26 PM
Member Group: Members Posts: 164 Joined: 8-February 05 From: San Rafael, CA Member No.: 3,578 Region Association: Northern California |
Speed nuts and rivets!
check out this site*: http://www.clipsandfasteners.com/ LOTS of stuff that could work on our cars, reasonable prices..they have something you'll want! * No affiliation. |
Jonathan Livesay |
Jun 3 2015, 04:21 PM
If you guys are talking about the kind of rectangular shaped metal ones, they do work, but be aware they do not come off nearly as easily as they go on. They can be used on the lettering, but I pity the fool who uses them on the grating material at each end of the lid and then ever hopes to get them off again... How about the fool who's DPO did that? (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 31st May 2024 - 05:32 PM |
