Flamethrower coil 1.5 ohm or 3.0 ohm? |
Geezer914 |
Jun 4 2015, 01:58 PM
Geezer914 Group: Members Posts: 1,444 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
What is the difference or advantage between a 1.5 ohm coil and using a 3.0 ohm coil with a Pertronix electronic ignition module? (IMG:style_emoticons/default/confused24.gif)
reharvey |
Jun 4 2015, 02:17 PM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
What is the difference or advantage between a 1.5 ohm coil and using a 3.0 ohm coil with a Pertronix electronic ignition module? (IMG:style_emoticons/default/confused24.gif) For our 4cyl. cars Pertronix manual says 3.0 ohm only! |
worn |
Jun 4 2015, 02:49 PM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
What is the difference or advantage between a 1.5 ohm coil and using a 3.0 ohm coil with a Pertronix electronic ignition module? (IMG:style_emoticons/default/confused24.gif) For our 4cyl. cars Pertronix manual says 3.0 ohm only! Are the lower resistance ones for higher amperage output CD boxes like MSD? I know that when I had trouble with an MSD box the rep told me that the type of plug wire is important. So I bought some new ones and never put the thing back in. |
JimN73 |
Jun 4 2015, 02:53 PM
Senior Member Group: Members Posts: 535 Joined: 6-October 07 From: Gig Harbor Member No.: 8,192 Region Association: Pacific Northwest |
I don't know about MSD, but Mallory requires a 1.4 ohm coil or a 3 ohm coil and a resistor.
Find out before you hook things up. Frying an ignition module on the freeway is not fun, but is expensive. |
Lo-Fi Version | Time is now: 9th June 2024 - 03:38 AM |
