Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
My car normally takes two turns of the key to start. It hardly ever makes contact on the first turn (of the key) but I hear the fuel pump. I was starting this way until recently, it's gotten worse, and now it won't start at all. Battery is good, system seems okay. I think it is the switch, it's about a year old. I can bump/push start the car easily, but I need to fix this. How hard, and what is the R & R procedure for the switch? Also, can I source this switch easily at my FLAPS?
Thanks (IMG:style_emoticons/default/headbang.gif) |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Typical shitty ignition switch electrics. Do you have a relay on your starter? It will help it last longer.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.tangerineracing.com-419-1434672810.1.jpg) |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,186 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Switches are NOT a FLAPS item in most cases. You will have to go VW sites or Pelican. Seems like there aren't any German ones any more. I THINK I saw some made by Dansk so the are NOT made in China.
Larmo63 |
I'm gonna dig into it tomorrow, i read the thread on the PP site.
Seems pretty easy, I've already done both of the switches behind the steering wheel. Grrr…. |
PlantMan |
Member ![]() ![]() Group: Members Posts: 438 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California ![]() |
I'm gonna dig into it tomorrow, i read the thread on the PP site. Seems pretty easy, I've already done both of the switches behind the steering wheel. Grrr…. I did it recently by using the PP article. The hardest part for me was removing the steering wheel but after I got that pulled it went pretty quick. I may have a spare and will PM you if I do. I am just down the road from you. |
Lo-Fi Version | Time is now: 6th July 2025 - 07:19 PM |
