914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,183 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
I though I would pick up a couple of these at $4 each as spares. One slight problem, they are missing a post. All 914 flashers early and late have 4 posts. Aren't reproductions supposed to be correct? (IMG:style_emoticons/default/headbang.gif) It would cost almost as much to return them as they are worth.
Attached image(s) ![]() ![]() |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Real ones are $50 each. Rich at high Performance House has real ones.
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,735 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
If you ain't returning it, plug it in to see what it does. Is the cover a ground or "the 4th" post?
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,185 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
It is possible that the missing post is the K/C2 terminal which drives the dash indicators. You can work around the missing terminal.
Kansas 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains ![]() ![]() |
I bought 2 of them and threw them in the drawer - didn't even open them.
I took it apart to see. BTW the coil is 24VDC: ![]() ![]() ![]() I also found this schematic online: ![]() |
914Sixer |
The range anywhere from a $14 and up depending on where you shop. What they are selling are for VW not 914.
Kansas 914 |
Mike Bellis |
A real flasher relay has 2 coils and 2 sets of contacts inside. One set flashes the exterior lights and the other flashes the dash indicator. That is why they have 4 terminals.
Kansas 914 |
Mike Bellis |
A real flasher relay has 2 coils and 2 sets of contacts inside. One set flashes the exterior lights and the other flashes the dash indicator. That is why they have 4 terminals. Is it just a DPDT? No. double coils, double single pole. |
Lo-Fi Version | Time is now: 3rd July 2025 - 03:17 AM |
