Signal light question |
pda914 |
Jul 7 2015, 05:27 PM
Newbie Group: Members Posts: 40 Joined: 22-July 10 From: Verona WI Member No.: 11,966 Region Association: None |
I am tracking down an apparent wiring issue. My right signal light stops working when signalling right with the headlights on. As you can see I don't drive this car at night and haven't noticed the problem till just recently. Tracing the wiring in the Haynes manual indicate that the side marker and one filament in the front turn signal light are to be on continuously when signalling on that side or when the headlights are on. What I see on my teener is that with the headlights off the side markers flash with the signal lights. When the headlights on the left and right side marker light stays on continuously and the left signal light work but when signalling right or with the emergency flasher switch on the flashing stopped,
My question is whether the Haynes manual is correct that the side markers are on continuously? Just need to clarify this before I contort myself to fit under the dash and rip apart the wiring which I presume the previous owners have miss-wired. |
MarkV |
Jul 7 2015, 09:09 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
Yes...they do stay on continuously
Mike Bellis |
Jul 7 2015, 09:16 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Wrong lamp
Corroded lamp socket corroded grounds Check them all. |
pda914 |
Jul 8 2015, 05:43 PM
Lo-Fi Version | Time is now: 7th June 2024 - 10:40 AM |
