Motor refresh (911) |
Ferg |
Jul 14 2015, 07:55 AM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
It was time to do a refresh on the 2.7 in the Carrera. Nice to have the help and good company of Brant, Gint, Sharon and Hines for the motor drop.
(IMG:style_emoticons/default/beerchug.gif) |
EdwardBlume |
Jul 14 2015, 08:07 AM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
Nice! What are you going to do to refresh it?
Ferg |
Jul 14 2015, 08:10 AM
Hines is in charge. (IMG:style_emoticons/default/aktion035.gif)
JmuRiz |
Jul 14 2015, 08:20 AM
914 Guru Group: Members Posts: 5,434 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
If you want to keep the CIS and want to do something as simple as a cam upgrade let me know and I'll sell you mine. I have an SC grind 3-bearing cam for a 2.7CIS engine...supposedly a nice upgrade.
I'm changing mine to carbs, but would like SC grind cam to go to a good home. |
Ferg |
Jul 14 2015, 08:23 AM
Thanks for the offer, but staying stock stock stock on this one, it's a numbers matching 75 Carrera.
Elliot Cannon |
Jul 14 2015, 08:38 AM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
They were all there to help? Where they any help? (IMG:style_emoticons/default/laugh.gif)
Ferg |
Jul 14 2015, 08:44 AM
Sharon supervised, I took pictures (IMG:style_emoticons/default/laugh.gif) I had it mostly ready to drop, just fuel line, and electrical, oh and the speedo cable I forgot to undo (IMG:style_emoticons/default/huh.gif) |
EdwardBlume |
Jul 14 2015, 08:45 AM
Who's the guy in flip flops? That's confidence!
Ferg |
Jul 14 2015, 08:51 AM
Nice! What are you going to do to refresh it? It's getting torn all the way down... Runs and drives fine now, I suspect I have a valve seat issue on #2, leak down is fine on the all the rest at 4 percent, but #2 is about 8 percent and have a tapping I cannot adjust out. Compression is even at 128 at my altitude of 5500. Uses about one quart per 1k. I have smoke on downshift. Motor has been done once long ago, but no records, so time to go all in. |
Ferg |
Who's the guy in flip flops? That's confidence! Hines and myself were in our OSHA approved footwear (IMG:style_emoticons/default/biggrin.gif) |
brant |
Jul 14 2015, 09:03 AM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I think my role was really just standing around
billh1963 |
Jul 14 2015, 09:06 AM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
Nice! What are you going to do to refresh it? It's getting torn all the way down... Runs and drives fine now, I suspect I have a valve seat issue on #2, leak down is fine on the all the rest at 4 percent, but #2 is about 8 percent and have a tapping I cannot adjust out. Compression is even at 128 at my altitude of 5500. Uses about one quart per 1k. I have smoke on downshift. Motor has been done once long ago, but no records, so time to go all in. Mine had a little smoke on startup, decent compression and leakdown numbers, etc. But, it also had a tapping coming from the left side that got louder as the engine warmed up. Oil pressure dropped as the car warmed up as well. My 2.7 is now undergoing a rebuild...previous rebuilder (before I bought the car) did not thoroughly clean the case so now the oil pump is shot and a couple galleries were partially blocked. Fortunately, the crank and cams are not damaged. I will be getting new pistons and relined cylinders (along with reworked heads and such). My case had already been time-serted. Make sure your block is clean after they are through with machining! (IMG:style_emoticons/default/chair.gif) |
SLITS |
Jul 14 2015, 11:05 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
That image of Hines is just SPOOKY!
sixnotfour |
Jul 14 2015, 05:49 PM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
That image of Hines is just SPOOKY! Well Ron, I thought I had lost my Nacho Again, butt he showed up the opposite direction we were looking....I thought I was A Dead Man......Suzie had Warned Me And I forgot , A Porsche Got in the way of Dog watching....So I was pretty relieved the little FR showed back up... (IMG:style_emoticons/default/beerchug.gif) Brant was instrumental in calling NACHO...and Making sure Gint was Clear.... |
gms |
Jul 16 2015, 03:24 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
Jeff you need to keep heading east...another 1000 mi
sixnotfour |
Jul 18 2015, 03:15 PM
rhodyguy |
Jul 19 2015, 07:28 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Here comes the HP! Jeff's choise of work boots always cracks me up.
Lo-Fi Version | Time is now: 10th June 2024 - 08:47 PM |
