Part request for 914rubber or Spoke, A low profile, semi-correct appearing wart |
Mark Henry |
Jul 26 2015, 05:26 PM
Something that looks right on the car, but sits low profile, preferably LED. Pretty please (IMG:style_emoticons/default/pray.gif) |
vw505 |
Jul 26 2015, 05:28 PM
Member Group: Members Posts: 228 Joined: 17-April 03 From: San Antonio, TX , Navy retired Member No.: 579 Region Association: None |
I would go for a set myself.
Mikey914 |
Jul 26 2015, 07:36 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
While this can be done. The real question becomes aesthetics. The tooling cost is reasonable, but what appeals one person, will not necessarily appeal to another. To make it work for me I have to look at producing 50- 100 sets. I often go long on these if they are factory parts to make them affordable. So yes I can your set is $800. The more that like them bring the cost down to about $26 a set at 100 sets.
Mark Henry |
Jul 26 2015, 09:35 PM
While this can be done. The real question becomes aesthetics. The tooling cost is reasonable, but what appeals one person, will not necessarily appeal to another. To make it work for me I have to look at producing 50- 100 sets. I often go long on these if they are factory parts to make them affordable. So yes I can your set is $800. The more that like them bring the cost down to about $26 a set at 100 sets. I was thinking just a lens that fits in the factory base almost flush and when looked at head on still looks like the factory wart. LED should make the bulb bit do-able. I though about just cutting the lens down, but it has a taper. Another idea is to cut the factory lens down and make a new smaller base. (IMG:style_emoticons/default/idea.gif) Once I get the /6 conversion done paint will be the next job, I would just delete the wart but I need to figure out something else for a marker. The front corners on the 914 are poorly lit without the wart. A good looking wart would be a good alternative. |
Dave_Darling |
Jul 26 2015, 10:47 PM
LED truck or trailer lights. You should be able to find one that fits--if you find one whose looks you like, you're golden.
--DD |
Lo-Fi Version | Time is now: 4th June 2024 - 03:00 PM |
