Opinions on these main bearings?, 2.7l /6 |
tornik550 |
Aug 9 2015, 05:16 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I do not know much about reading bearings upon disassembly. I have several cases and I just took a look at these bearings for the first time. I know absolutely nothing about the history of this case. What are your opinions on the bearings? If I use this case, of coarse I will use new bearings. This is more for forensic fun
tornik550 |
Aug 9 2015, 05:17 PM
More
tornik550 |
Aug 9 2015, 05:19 PM
More
I didn't notice til I saw the pictures but there is are some white plastic shavings on the bearings from something else I was doing. Attached thumbnail(s) |
tornik550 |
Aug 11 2015, 01:45 AM
What I was hoping that some one could answer- is the wear pattern on the bearing with the thrust surfaces a normal wear pattern (no sure how the bearings are named)? If not, any guess as to what would cause this kind of wear?
porschetub |
Aug 11 2015, 02:33 AM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
What I was hoping that some one could answer- is the wear pattern on the bearing with the thrust surfaces a normal wear pattern (no sure how the bearings are named)? If not, any guess as to what would cause this kind of wear? Pics not very good ,but they appear OK,some spotting on the whitemtetal surfaces can be a number of things,seperation of the whitemetal is an alarm waiting to ring,however. There appears some light scuffing of the surfaces but without knowing the mileage of the motor and couldn't say thats one way or the other,but it appears normal. Be very careful what main bearing you replace with as there have been serious issues with the commonly used Glyco replacement bearing of late. This is well documented on Pelican and I believe the rebuild guru's refuse to use them now,cheers. |
Mark Henry |
Aug 11 2015, 06:43 AM
They look like normal wear, you would need to plastigauge them to be sure.
If good I'd DFL (Dry Film Lube) them I done this (I can do this) and it works good. If you do decide to replace them, I'll take them (IMG:style_emoticons/default/shades.gif) I'm looking to put together a back-up engine. |
tornik550 |
Aug 11 2015, 11:08 AM
Mark- you can have the bearings if you want however it looks like they are Glyco bearings.
What are the go to bearings to buy now for mains and rods? PP forums have some bad stuff about the glycos. |
gereed75 |
Aug 11 2015, 11:18 AM
Senior Member Group: Members Posts: 1,261 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Mark- you can have the bearings if you want however it looks like they are Glyco bearings. What are the go to bearings to buy now for mains and rods? PP forums have some bad stuff about the glycos. From my vast experience (one engine re build), I would say that this looks like typical wear as the bearing journals begins to ovalize. They will go out of round "spreading" at the case join line. Measure carefully for this. If they are out of round by .002" or so, you might be fine. More than .004" and the crank will bind as you torque the cases together It is hard to read through all of the glyco problem threads. It seems most of the problems were on the bigger bore motors. I bought the glyco''s from EBS for my 2.4 build. I guess I trusted them to say if there was a problem. They said nothing. |
6freak |
Aug 11 2015, 11:58 AM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
pitting and frosted..there junk imo
Lo-Fi Version | Time is now: 13th June 2024 - 08:13 AM |
