shandyhaggis |
Newbie ![]() Group: Members Posts: 49 Joined: 2-February 11 From: UK Member No.: 12,653 Region Association: None ![]() |
Hello all
Ive got the stage of my restoration that I have the pleasure of fitting all new shiny brake lines. Ive got some pre-made ones from MittleMotor in Germany and Im just going through the process of figuring out which pipe is used where. Ive got the 914 PET which is useful to locate roughly where pipes run but it doesnt show pipe lengths which would have been useful. Does any one have any pointers on generally fitting new pipes? I cant find any pictures showing how the lines run. Its a long time since I pulled the old ones out and I didnt take any snaps:-( thanks if you can help! Andrew |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,908 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Might try some of the different shop manuals. The PET is the best source I would go to.
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Just dig in. In a few minutes, reasonable deduction and the process of elimination will have you sussed.
Long one = center tunnel Two Shepards hooks = rear caliper hardlines Little L = Pressure regulator to center tunnel Medium sized line with a crescent = Front right etc... |
shandyhaggis |
Might try some of the different shop manuals. The PET is the best source I would go to. thanks Ive a pdf of the workshop manuals but it doesnt cover it off. Im sure can work it out, Ive the old brake lines to compare against somewhere though they are crumpled in a box. Most things Ive done Ive figured out I was just trying to be extra careful with the pipes as I didnt want to mess it up. thanks Andrew |
shandyhaggis |
Just dig in. In a few minutes, reasonable deduction and the process of elimination will have you sussed. Long one = center tunnel Two Shepards hooks = rear caliper hardlines Little L = Pressure regulator to center tunnel Medium sized line with a crescent = Front right etc... thanks for that. Ive my old pipes I can compare against if I gently unfold them from the ball I made of them when I ripped them off the car (note to self for next time). The new pipes arnt shaped so Ill have to check the lengths aginst he old ones to make sure Ive got the right one. If I mess up I can always by a length or 2 with an couple of tools and make some new ones up. thanks Andrew |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,322 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Like Eric said, it really shouldn't be to hard to see what goes where. There aren't that many lines and they only fit one way. If you run into problems, take pics and post here.
falcor75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia ![]() ![]() |
shandyhaggis |
Lo-Fi Version | Time is now: 14th June 2024 - 01:32 PM |
