1.7 Running Issues |
lennyhope |
Aug 13 2015, 09:07 AM
Member Group: Members Posts: 168 Joined: 2-November 11 From: prescot Member No.: 13,736 Region Association: England |
My 1.7 injection was running great and then wasn't. Starts first thing from cold. Idle sometimes steady as a rock and then drops off and dies. Then it is difficult to start again unless I wait at least half an hour or so. Ideas???.
914_teener |
Aug 13 2015, 10:21 AM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Yes.
Check the MPS with a vacuum leak down test first. Diaphragm could have cracked. Then check back. |
Bob L. |
Aug 13 2015, 11:42 AM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
Also check vacuum hoses for cracks or loose connections.
lennyhope |
Aug 13 2015, 11:53 AM
BeatNavy |
Aug 13 2015, 12:39 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Based on the limited info you provided, I can only suggest keeping the CHT in your lineup of "usual suspects" (if you haven't already eliminated that as a possibility). When it fails, or is failing, or when the wiring harness develops breaks (even if you can't see them), the car may start when cold then die quickly thereafter.
If you haven't already, spend some time here: http://members.rennlist.com/pbanders/djetp...tm#troubleshoot |
Lo-Fi Version | Time is now: 7th June 2024 - 12:49 PM |
