Looking for some 96.0mm cylinders, 96.0mm cylinders |
lonewolfe |
Aug 15 2015, 06:48 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
I'm looking for 96.0mm cylinders and have basically found them at EMW for $200 a set.
AA pistons for $179 (out of stock for 2-3 weeks), DRD for $300 a set(from Japan) and finally QSC for $106. There's quite a price range for these. I imagine the first 3 are made in China and are perhaps all the same. I don't know if the DRD's are superior or not. What type cylinders have you used successfully? Any feedback is appreciated! |
Alphaogre |
Aug 15 2015, 07:31 PM
Member Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California |
After just going through all this research and upgrading to 96mm pistons, I ended up with Keith Black pistons from DRD.
It will really come down to what you plan to do with the motor and what you are working with. Everyone I talked to, which included shops and retailers, the AA pistons are fine if you are just driving around and not pushing the engine to hard. From what I understand their tolerances are not as tight and there can be some QC issues. Since I am planning to do AX and TT events, I was advised to not use any of the AA stuff and look into JE forged pistons. Since I was working with a 1.7 this meant I was going to have to do a custom order. This was longer and just a bit more expensive then I was looking to do. The guys at DRD were the ones that advised to go with the Keith black pistons, and they make the jug with the piston with a much closer tolerance than the AA kit. They mentioned that I really didn't the need a forged piston until you get to around 40 hp per cylinder. And I'm not planning to build the motor much bigger then the jug/piston swap. I posted the narrowed down options on my thread here. http://www.914world.com/bbs2/index.php?sho...259705&st=0 |
Mueller |
Aug 15 2015, 08:17 PM
Who is DRD?
lonewolfe |
Aug 15 2015, 09:00 PM
drdracingheads.com
StratPlayer |
Aug 16 2015, 04:09 AM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
I had a pair of OEM cylinders bored out to 96mm then I used keith black pistons with hastings rings.
Mark Henry |
Aug 16 2015, 09:46 AM
I wouldn't use anything but the KB (or JE) pistons.
lonewolfe |
Aug 16 2015, 10:56 AM
I failed to state that I already have a set of JE pistons. I'm only looking for the cylinders.
stugray |
Aug 16 2015, 11:05 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Have some stock 94s bored to 96.
mbseto |
Aug 16 2015, 12:04 PM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
Anyone ever tried motorcycle cylinders?
lonewolfe |
Aug 19 2015, 11:25 PM
Bumping this back up with hopefully better weekday response. What 96.0mm cylinders have you used and recommend?
TheCabinetmaker |
Aug 20 2015, 04:57 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Your looking for a better answer? You've already got the best answers. Keith black pistons. Bored OEM cylinders.
colingreene |
Aug 20 2015, 05:33 AM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
i think the EMW cyls are made in india?
Call him and ask. they have been fine in my car.... |
Mueller |
Aug 20 2015, 08:11 AM
Anyone ever tried motorcycle cylinders? I would think the odds of finding cylinders that meet all the dimensional requirements would be fairly low unless one is looking for some really oddball combo. Not a totally insane question, however since cylinders and pistons are so easily available unless one has access to said MC cylinders or lives in a 3rd world country with no access to new parts, I don't see anyone doing this. |
Mueller |
Aug 20 2015, 08:13 AM
i think the EMW cyls are made in India? Call him and ask. they have been fine in my car.... Not trying to get too OT http://www.nytimes.com/2007/11/26/nyregion...nhole.html?_r=0 Casting parts in India.... |
lonewolfe |
Aug 20 2015, 04:30 PM
Your looking for a better answer? You've already got the best answers. Keith black pistons. Bored OEM cylinders. I already have a new set of JE Pistons and I don't have any stock 2.0 cylinders to bore out. I want to buy a set of new 96.0 cylinders and that is why I asked you all for your opinions & experience on what cylinders you've used successfully. |
Dtjaden |
Aug 20 2015, 09:19 PM
Member Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California |
EMW
Lo-Fi Version | Time is now: 1st June 2024 - 12:15 AM |
