Rear View Mirror Adhesive |
Olympic Blue |
Aug 18 2015, 03:27 PM
Newbie Group: Members Posts: 1 Joined: 18-August 15 From: Louisville Member No.: 19,079 Region Association: South East States |
I am re-attaching the rear view mirror to the inside of the windshield, (using the correct adhesive "pad"), and I am noticing some old adhesive that was used to adhere the mirror to the glass. A big deal since it is a few inches outside of the place where the mirror will adhere to the windshield. I can't seem to remove it - almost as if it has etched the glass. Any ideas on how to remove this? Thanks!
screenguy914 |
Aug 18 2015, 05:04 PM
Member Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
I am re-attaching the rear view mirror to the inside of the windshield, (using the correct adhesive "pad"), and I am noticing some old adhesive that was used to adhere the mirror to the glass. A big deal since it is a few inches outside of the place where the mirror will adhere to the windshield. I can't seem to remove it - almost as if it has etched the glass. Any ideas on how to remove this? Thanks! What have you tried? Razor blade? If below the surface of a blade, it's in the glass. |
Tom_T |
Aug 18 2015, 06:52 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Also if that doesn't work &/or in addition to - try first the citrus based adhesive removers (Goo Gone, etc.), then achohol, & then if that's not working try acetone & work slowly to let it dissolve the crud (that removes super glue, if you had a super-DAPO put it on before). Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Lo-Fi Version | Time is now: 1st June 2024 - 03:12 AM |
