pls comment on my wiring. and i have questions too. |
jimkelly |
Aug 23 2015, 06:33 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
I have a non working horn and wipers. I decided to by pass the cars harness and run switches and relays to power these for now. to get thru inspection.
1- what guage wire needed for wiper motor and what amp fuse? 2- what gauge wire needed for horn and what amp fuse? 3- what gauge wire needed for two radiator fans and what amp fuse? thanks!!! jim Attached thumbnail(s) |
jimkelly |
Aug 24 2015, 03:01 PM
got another fuse block at advance today. a buddy of mine suggested i use 10 gauge wire all the way to my wiper, and horn & radiator fuse block. so i will be swapping out the 14 gauge i used in these segments.
he suggested a 5 amp fuse for my horn, 2 amp for wiper, and a 10 amp for radiators, but he is not a 914 owners, just guessing. |
Chris914n6 |
Aug 24 2015, 04:25 PM
Jackstands are my life. Group: Members Posts: 3,337 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I'd just fix the factory wiring. I think it was all 16ga, but it's in the wiring diagrams.
I ran 8 ga to the front to a fuse block. Powers 2 fans, headlights, windows and amp so far. 20-30 amp fuses mostly because that's what I had. |
Tom |
Aug 24 2015, 11:00 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Non working horn and wipers would make me want to check J13 on the fuse panel of the stock set up. It also runs the fresh air blower and in the Haynes manual is called the fresh air blower relay.
If you have modified stock wiring and maybe damaged wiring harnesses from a previous owner and need to go with separate wiring: Your 10 ga. to the fuse block is OK as long as you do not put too much on your new fuse block. Say horn - 5 amps 14 ga. wire OK wipers- probably 5 amps, but try a 7.5 if the 5 blows 14 ga OK Radiators fans - here you need to test them and use an ampmeter to really know what they are drawing. Then double what one needs and add 50%, Say 5 to 7.5 amps each. so 10 or 15 amps times 1.5. A 12 gage wire is good for say 20 amps all day long considering the length of your run ( maybe 10 feet?). Tom |
jimkelly |
Aug 25 2015, 07:06 AM
tom - thanks - jim
i know fixing it the RIGHT WAY is best but since i have to run 12V to my radiators the right way, i figured for temporary, i would fix/power my horn and wipers HALF ASSED for now : ) |
JeffBowlsby |
Aug 25 2015, 10:11 AM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Temporary has a way of becoming permanent. You don't want to be a DAPO do you? Fix it right the first time.
jimkelly |
Aug 25 2015, 11:40 AM
guess i need a multimeter and need to learn how to use it. this will have to be PHASE 2 : )
bozo914 |
Aug 25 2015, 12:01 PM
Slacker Group: Members Posts: 284 Joined: 27-October 10 From: Richmond VA Member No.: 12,325 Region Association: MidAtlantic Region |
guess i need a multimeter and need to learn how to use it. this will have to be PHASE 2 : ) That explains why you're running new wire for things already in the harness - get the multimeter. It ain't rocket science. It's 45 year old wiring and components, in a 45 year old car, that has suffered through god knows what sort of abuse. If I can use one so can you. (IMG:style_emoticons/default/biggrin.gif) |
Dave_Darling |
Aug 25 2015, 05:52 PM
Even a $20 a Harbor Freight special is good enough multimeter for our purposes. You mostly need to see if something has +12V on it or not, and sometimes measure resistance in the ~10-10K ohms range. And the exact values are almost never important for our use.
--DD |
jimkelly |
Aug 26 2015, 07:00 AM
would this be a decent meter?
what features would be missing that i might want in the future? http://www.fluke.com/fluke/inen/digital-mu...1.htm?pid=77003 Attached image(s) |
Dave_Darling |
Aug 26 2015, 09:15 AM
Yes. Maybe overkill, even. Basically any voltmeter/ohmmeter will work for what we need on our old cars.
--DD |
stinkindiesel |
Aug 26 2015, 01:21 PM
Member Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
Fluke meters are the gold standard. Great to have if you use it often, but overkill for the typical hobbyist.
Gary |
jimkelly |
Aug 26 2015, 01:29 PM
i pulled the trigger, $55 shipped on ebay. fluke 101.
Lo-Fi Version | Time is now: 9th June 2024 - 02:14 AM |
