Fuel Guage in a Six |
kupcar |
Aug 24 2015, 12:59 PM
Member Group: Members Posts: 95 Joined: 14-February 13 From: Chicago Member No.: 15,528 Region Association: None |
Hi Guys, Who does the six tri-guage modification to put the fuel guage in the oil temp/pressure guage on a six conversion? Cost?
gereed75 |
Aug 24 2015, 01:16 PM
Senior Member Group: Members Posts: 1,249 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
0396 |
Aug 24 2015, 01:59 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Search is your friend
Steve |
Aug 24 2015, 02:14 PM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Check the member vendor forum on this site. John did mine a while back. Awesome job, but I don't know if he is still doing them. A lot of these vendors do this part time, so you can't be in a hurry. If your in a hurry pay more and go to Hollywood speedometer
http://www.914world.com/bbs2/index.php?sho...=58970&st=0 |
GeorgeRud |
Aug 24 2015, 02:52 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
914forme |
Aug 24 2015, 06:15 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Some GTs had them mounted in the factory radio blank spot. Easy enogh to fab, VDO makes a nice round one that fits perfectly and works. (IMG:style_emoticons/default/poke.gif)
This is coming from the guy that made the first run of 904 gauges. BTW, it is fun, you can make them yourself, some where in here, I have a entire build thread on how to do it. But then John does a great job, much better than my originals. And his price is a bargain. (IMG:style_emoticons/default/thumb3d.gif) |
Cairo94507 |
Aug 24 2015, 07:34 PM
Michael Group: Members Posts: 9,808 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Palo Alto Speedometer, (Palo Alto, CA) is doing my gauges. Here is the rendering. My gauges should be done pretty soon. I have no idea what the bill will be.....pretty crazy, huh?
BobMC914 |
Aug 24 2015, 08:58 PM
Newbie Group: Members Posts: 8 Joined: 5-August 15 From: Houston, Tx Member No.: 19,029 Region Association: Southwest Region |
Not to hijack, but does anyone know if there is a small VDO fuel gauge that works with the stock sender?
I'd like to mount a small fuel gauge in the console on my car in place of the clock. That way I can avoid having to do the triple gauge, at least for a while. If I have to replace the sender it doesn't really save me anything but a little time over the triple gauge. |
earossi |
Aug 24 2015, 09:09 PM
Member Group: Members Posts: 210 Joined: 8-December 11 From: Chicago, Il Member No.: 13,878 Region Association: Upper MidWest |
Palo Alto Speedometer, (Palo Alto, CA) is doing my gauges. Here is the rendering. My gauges should be done pretty soon. I have no idea what the bill will be.....pretty crazy, huh? I recently had a gauge package done for my /6 conversion. I had the fuel level/oil temp gauge converted to oil pressure and oil temperature. I supplied a 911 turbo tach which has a central located boost gauge on the guage. I had the boost gauge modified to be fuel level. I also supplied a 914 speedometer. All the the gauges were restored and had new faces installed. I got pricing from both Hollywood and Palo Alto, and they were very close. All said and done, the work ended up costing right at a little over $1000, so they are not cheap. That should give you an idea of the approximate cost to refurbish a set of 914 gauges for a /6 conversion. Obviously, if you are only looking for a triple gauge, the cost will be less than what I paid. |
kupcar |
Aug 24 2015, 10:25 PM
I'm new to this car, so I'm trying to work out all the kinks that the previous owner failed correct. Operating without a fuel guage is silly. I love the combo guage, just not sure I'm ready to pony up the $1k to do it now. I'm also trying to figure out why my speedo is registering slow. Haven't investigated if it's a problem with the speedo or cable mechanism coming off the 901 gearbox. I don't have a center console, so my other options are the ashtray or radio faceplate location. Am I correct by thinking that the original sender should work with a 12v vdo guage made for a Volkswagen application?
Such a fun car yo work on! Thanks again to everyone for all the ideas and help. |
Cairo94507 |
Aug 25 2015, 06:24 AM
Johny Blackstain |
Aug 25 2015, 07:10 AM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
Not to hijack, but does anyone know if there is a small VDO fuel gauge that works with the stock sender? I'd like to mount a small fuel gauge in the console on my car in place of the clock. That way I can avoid having to do the triple gauge, at least for a while. If I have to replace the sender it doesn't really save me anything but a little time over the triple gauge. Yes, it's what I did. I've got a 911 oil temp/pres gauge in the dash & a small VDO tank gauge in my center console. Attached thumbnail(s) |
914forme |
Aug 25 2015, 07:48 AM
It is the center gauge in the console above, as you can see it is a 1/4 sweep then a large reserve area.
See if John is still doing the 904 gauges, he is more reasonable than Palo Alto. Or you can build one yourself it you so desire. This will let you know what your in for. I stumbled across all the design and paper work I have for the kits I did. It is public domain information, so you can use it to your hearts content. I can post the design pieces if you want. Another option is to use a 930 Tach, and put the fuel gauge in there instead of the oil pressure, and keep all the oil gauges in one window. BTW, you can also do a quad gauge using a 924 gauge, and then a custom back plate. Please get rid of the Madonna cone bras if you do them. You can also change them all out and use Speedhut for them. Modren instruments, shallow mounting and fully customizable for a 5-6 uncle ben's. Go full 911, and install a Getty Dash. So many options just depends on what you want to do. |
Jeffs9146 |
Aug 25 2015, 10:58 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Here is where I mounted mine.
JmuRiz |
Aug 25 2015, 12:19 PM
914 Guru Group: Members Posts: 5,433 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Not to hijack, but does anyone know if there is a small VDO fuel gauge that works with the stock sender? I'd like to mount a small fuel gauge in the console on my car in place of the clock. That way I can avoid having to do the triple gauge, at least for a while. If I have to replace the sender it doesn't really save me anything but a little time over the triple gauge. Yes, it's what I did. I've got a 911 oil temp/pres gauge in the dash & a small VDO tank gauge in my center console. Nice, I was thinking of something similar but with a triple in the dash. Nice to see a real picture of gauges at the top of a deposit box. |
Johny Blackstain |
Aug 25 2015, 01:20 PM
Nice, I was thinking of something similar but with a triple in the dash. Nice to see a real picture of gauges at the top of a deposit box. (sorry for the hijack) Thanks. It's the stock deposit box that came w/ my six. I cut a piece of steel, bent it & cut 3 gauge holes in it for the clock, voltmeter & gas gauge. Then I covered it w/ dash material & bolted it to the top of the box. Since my other teener came w/ the center gauge console there, it seemed logical to do the same to the six. Attached image(s) |
kupcar |
Aug 25 2015, 03:27 PM
No apologies necessary for the hijack. All this information is good! The more ideas the better.
Cairo94507 |
Aug 25 2015, 03:53 PM
I like the gauges in the deposit box - I almost went that way, it was a close call.
patssle |
Aug 25 2015, 07:33 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Lo-Fi Version | Time is now: 1st June 2024 - 06:00 AM |
