WTB Crank shaft spacer, pilot bearing spacer |
rfinegan |
Sep 8 2015, 05:42 PM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
I need the split sleeve spacer found in the back of the crank shaft that keeps the needle bearing pilot bearing from entering the crank shaft to far. Was missing from my motor so I had to take it out of the one on my bench
thanks -Robert Attached image(s) |
euro911 |
Sep 8 2015, 05:54 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I need the split sleeve spacer found in the back of the crank shaft that keeps the needle bearing pilot bearing from entering the crank shaft to far. Was missing from my motor so I had to take it out of the one on my bench (IMG:style_emoticons/default/confused24.gif) Pix pleasethanks -Robert |
rfinegan |
Sep 9 2015, 04:16 AM
I need the split sleeve spacer found in the back of the crank shaft that keeps the needle bearing pilot bearing from entering the crank shaft to far. Was missing from my motor so I had to take it out of the one on my bench (IMG:style_emoticons/default/confused24.gif) Pix pleasethanks -Robert Updated post with pic and description |
914ltd |
Sep 9 2015, 05:45 AM
Member Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None |
The spacer is unused on the 914. Install the pilot so there is enough space the felt wick (#21 soak with engine oil) is flush with the bolt surface of the flywheel. The pilot will stick out the crankshaft side about 3mm. Happy assembling! Brad |
rfinegan |
Sep 11 2015, 06:46 AM
Does someone have one the can measure the dimension for me and I will have one made. A little to much work for me to get out now that its back together...
-Robert |
rfinegan |
Sep 15 2015, 04:18 AM
Still need/looking
TheCabinetmaker |
Sep 15 2015, 05:01 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Like Brad said. You don't use it on a type 4.
Lo-Fi Version | Time is now: 3rd June 2024 - 12:30 AM |
