Swaybar removal |
Swaybar removal |
mepstein |
Sep 12 2015, 01:16 PM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
How do I remove the swaybar once I removed all the bolts and drop links. Doesn't seem like the ends will slide out from the triangle bushings.
stevegm |
Sep 12 2015, 01:22 PM
Advanced Member Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States |
How do I remove the swaybar once I removed all the bolts and drop links. Doesn't seem like the ends will slide out from the triangle bushings. I am assuming you are talking about an original sway bar for the front. You have to pull the triangle plate off and the bushing out. The bushing is split so it will come out. You only have to take it out of one side. I have seen people drive the whole bar out one side. And I have also seen people just work the bushing/traingle plate off. I think the latter is the way to go. |
sfrenck |
Sep 12 2015, 01:23 PM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
toolguy |
Sep 12 2015, 01:25 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
remove the rubber bushings that are stuck in the mount then the bar should pull straight out of either side. . may need some rubber lube and a mallet
mepstein |
Sep 12 2015, 01:27 PM
I think the bushing is rock hard from age. I'll go medieval on it. Thanks
GaroldShaffer |
Sep 12 2015, 01:35 PM
You bought another 914? Group: Benefactors Posts: 7,623 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Apply a little heat to cover over the bushing then take a flat
Screw driver and pry the cover off. |
john77 |
Sep 12 2015, 08:30 PM
Senior Member Group: Members Posts: 621 Joined: 21-February 14 From: Los Angeles Member No.: 17,027 Region Association: Southern California |
I used a big ass rubber mallet on mine. Not sure if it's a common problem, but I took mine out to replace the bushings and it was a real pita to get back through both holes. In the end I tied a piece of wire through the cotter pin hole and pulled it back through the hole instead of trying to push it. This was with a weltmeister 22mm bar, not the factory one.
Lo-Fi Version | Time is now: 2nd June 2024 - 07:46 PM |
