Power coating rims, Mahles |
BarberDave |
Mar 7 2005, 07:31 AM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
I am going to be powder coating my rims,( Mahles) what has been the experence out there. Main reason is durability of finish.and easy of cleaning. Dave (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) |
skline |
Mar 7 2005, 07:40 AM
Born to Drive Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
Ideal way to go in my opinion. I like the Mahle wheels over all the others. I like the Fuchs too but have seen many of them crack during AX. I have never seen a Mahle crack. I almost had a set till the rootbeer car got sold. I couldnt come up with a set of Fuchs to replace them with so the car sold with the Mahles. Oh well, I am not in a hurry. You are going to go with the Wurth Silver right??
ArtechnikA |
Mar 7 2005, 07:44 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
if you can afford it, go with the 75HP power coat; otherwise, the 50HP is good... |
BarberDave |
Mar 7 2005, 09:19 AM
Yes they wiil be stock silver ,or as closeas possable. ArtechnikA , what is the difference between 75 hp and 50 hp, power coater is sending samples, is there one that is better. Thanks Dave (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/alfred.gif) |
mikerose |
Mar 7 2005, 09:22 AM
Happy to be back Group: Members Posts: 657 Joined: 31-December 02 From: Pittsburg,ca Member No.: 60 Region Association: None |
HAHAAAAAAAAaaaaaaaaaaa (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) mike (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) |
BarberDave |
Mar 7 2005, 12:12 PM
OK, I should have used SPELL CHECK. But this is a example to you young guys. What old age does to you. Have pity please!!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Ok is the any difference in types of POWDER coating. Laughing at myself Dave (IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif) |
David Mueller |
Mar 11 2005, 10:11 AM
Member Group: Members Posts: 79 Joined: 4-February 03 From: Calgary, Alberta Canada Member No.: 236 |
The fellow you re-finsihed my Mahle's didn't recommend powder coating he said powder ocating works best on steel rims. He said the material the Mahle's are made of can become compromized when subjected to the high heat of powder coating...
Maybe he was full of CR*P too... Any have any comments... |
jmargush |
Mar 11 2005, 11:12 AM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I had my Mahles done in two colors. center one color and rim another. Heat of powder coating shouldn't affect the material. your only looking at about 400 degrees.
Attached image(s) |
jmargush |
Attached image(s) |
Ferg |
Mar 11 2005, 11:57 AM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
I had my ATS's done in a satin black and they turned out very nice, and so far no chips, but they only have one track weekend on them...
I have also heard that powder coating wheels especially cast wheels can possibly make them weaker, I forwared that info to my friend who is in the business and also a shifter cart racer and powdercoats many parts of his own , and he said it could be true but for wheels he bakes them in a two step heat process slightly lower to start and has not had any problems of parts failing. So from what I know nobody knows for sure (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Mine: Attached thumbnail(s) |
Lo-Fi Version | Time is now: 5th June 2024 - 07:14 AM |
