New to me 914, 914 renegade |
Mike1981 |
Oct 14 2015, 06:14 PM
Member Group: Members Posts: 212 Joined: 21-July 14 From: Detroit MI Member No.: 17,663 Region Association: Southern California |
Hello Everyone
Just took possession of this 1972 914 It has a 327 Chevy Small block with performance cams KEP Clutch/Adapter Still learning how the car handles but for my 2 short rides it is alot of fun Needs some small paint repair (rust bubbles) Otherwise I am very pleased with my purchase (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-17663-1444868069.1.jpg) |
SKL1 |
Oct 14 2015, 06:29 PM
Senior Member Group: Members Posts: 1,603 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
With that engine, you may want to upgrade your brakes, etc... I see you still have 4 bolt original hubs and brakes... (IMG:style_emoticons/default/smile.gif)
Mike1981 |
Oct 14 2015, 06:47 PM
Thanks
The front brakes are BMW The rears are the front 914 calipers They stop the car really well Also they have racing grade pads The hubs are 4bolt What do I get if I upgrade to 5 Bolt?? |
Bruce Hinds |
Oct 14 2015, 09:35 PM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
5 bolt may give you a better selection of a wider selection of wheel sizes. Just going a little bit wider and slightly larger in tire size will make a world of difference in handling.
I've not seen the figures, but a 205/50 or 206/60 on a 7 inch wheel will about double the footprint of the original 165 on the 5.5 inch wheel. Sway bars? With the right wheel and tire combo, some sway bars and the suspension set right, you'll really be able to take advantage of the V8. If you don't do any drag racing, the gear box and ring and pinion should hold up fine. CV joints usually fail when you accelerate hard out of a corner and light up the inside tire. That's where traction will help a lot, not to mention learning careful application of that power. Enjoy- |
flmont |
Oct 14 2015, 10:11 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
What kind of power does the 327 make as it sits,..???
Maltese Falcon |
Oct 14 2015, 10:48 PM
Advanced Member Group: Members Posts: 4,693 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Please give us a better description of the build of the engine, like what is the camshaft profile (you would not have camshaft(s)in a sb chevy).
The 327 came as a lowly 210 bhp 2 barrel carb. OR all the way up to a 375 bhp f.i. engine with a solid lifter cam. The latter goes into a classic corvette...doubtful that it's in your car. Enjoy the v8, but get some decent brakes + cv joints ! |
Chris914n6 |
Oct 14 2015, 11:42 PM
Jackstands are my life. Group: Members Posts: 3,332 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
5 lug = 911 front suspension. You get a wide selection of vented rotors, plus more choices in wider correct offset wheels. Not cheap but is a valuable upgrade.
1stworks |
Oct 15 2015, 08:00 AM
Member Group: Members Posts: 491 Joined: 31-March 13 From: colorado Member No.: 15,718 Region Association: None |
Welcome to the dark side.
Nice looking car,enjoy! |
whitetwinturbo |
Oct 15 2015, 10:19 AM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
Post more "darkside" pictures (IMG:style_emoticons/default/beer.gif)
Here's the slippery slope of 5 lug set ups: |
Bruce Hinds |
Oct 15 2015, 10:52 AM
Post more "darkside" pictures (IMG:style_emoticons/default/beer.gif) Here's the slippery slope of 5 lug set ups: There are lots of 5 lug wheel options too that will fit under the narrow body fenders and you don't have to go to flares. |
EdwardBlume |
Oct 15 2015, 12:59 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
Hello Everyone Just took possession of this 1972 914 It has a 327 Chevy Small block with performance cams KEP Clutch/Adapter Still learning how the car handles but for my 2 short rides it is alot of fun Needs some small paint repair (rust bubbles) Otherwise I am very pleased with my purchase (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-17663-1444868069.1.jpg) Congratulations! (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) |
Mike1981 |
Oct 15 2015, 01:00 PM
Hello All
I will list the upgrades to this vehicle: 1968 Chevy 327 large main journal heads post 1987 Chevy 4 bolt stainless 1.94 intake 1.5 exhaust Camshaft Crane Cams??5840 hydraulic Clutch/Flywheel Kennedy Eng Products Stage III 9" KEP Stage III Pressure Plate KEP 228mm flywheel KEP Pilot/throw-out bearing Fuel MGT Intake Manifold Pro products "typhoon" Holly Carb 600 double pump Mr Gasket fuel pump Mr Gasket pressure reg 2 inline fuel filters K&N air filter Open System no thermostat 2 row aluminum radiator Ford Tarus SHO fan 2350 CFM 185 degree fan switch 1970 Dodge water-pump 440ci impeller Exhaust 1980 Corvette headers Thrush turbo mufflers (Drone pretty bad from 1600 to 2400 RPM) Brakes Rotors...stock Front 1980 BMW 320i Rear porsche 914 fronts 911 master cylinder proportioning valve replaced with t Ignition Distributor Stock HEI type Coil: Accel Plugs AC Delco CR43TS 100AMP alternator 1 wire Starter IMI high Torque Suspension Turbo Tie rods KB struts front Bilstien coil overs rear Front torsion bar 911 MOMO steering wheel Rims American Racing Tires 205 50 R 15 Falken estimated HP 325 Estimated torque 350 ft-lbs This was sent to me from the previous owner who did the re-build It also has a roll bar and racing seats set up for racing with camber 1.5 front and back Still getting used to the ride lots of power lots of fun thanks for any advice |
Mike1981 |
Oct 16 2015, 08:25 AM
Hello All I will list the upgrades to this vehicle: 1968 Chevy 327 large main journal heads post 1987 Chevy 4 bolt stainless 1.94 intake 1.5 exhaust Camshaft Crane Cams??5840 hydraulic Clutch/Flywheel Kennedy Eng Products Stage III 9" KEP Stage III Pressure Plate KEP 228mm flywheel KEP Pilot/throw-out bearing Fuel MGT Intake Manifold Pro products "typhoon" Holly Carb 600 double pump Mr Gasket fuel pump Mr Gasket pressure reg 2 inline fuel filters K&N air filter Open System no thermostat 2 row aluminum radiator Ford Tarus SHO fan 2350 CFM 185 degree fan switch 1970 Dodge water-pump 440ci impeller Exhaust 1980 Corvette headers Thrush turbo mufflers (Drone pretty bad from 1600 to 2400 RPM) Brakes Rotors...stock Front 1980 BMW 320i Rear porsche 914 fronts 911 master cylinder proportioning valve replaced with t Ignition Distributor Stock HEI type Coil: Accel Plugs AC Delco CR43TS 100AMP alternator 1 wire Starter IMI high Torque Suspension Turbo Tie rods KB struts front Bilstien coil overs rear Front torsion bar 911 MOMO steering wheel Rims American Racing Tires 205 50 R 15 Falken estimated HP 325 Estimated torque 350 ft-lbs This was sent to me from the previous owner who did the re-build It also has a roll bar and racing seats set up for racing with camber 1.5 front and back Still getting used to the ride lots of power lots of fun thanks for any advice wow not one comment on list of upgrades?? |
1stworks |
Oct 16 2015, 10:05 AM
Hello All I will list the upgrades to this vehicle: 1968 Chevy 327 large main journal heads post 1987 Chevy 4 bolt stainless 1.94 intake 1.5 exhaust Camshaft Crane Cams??5840 hydraulic Clutch/Flywheel Kennedy Eng Products Stage III 9" KEP Stage III Pressure Plate KEP 228mm flywheel KEP Pilot/throw-out bearing Fuel MGT Intake Manifold Pro products "typhoon" Holly Carb 600 double pump Mr Gasket fuel pump Mr Gasket pressure reg 2 inline fuel filters K&N air filter Open System no thermostat 2 row aluminum radiator Ford Tarus SHO fan 2350 CFM 185 degree fan switch 1970 Dodge water-pump 440ci impeller Exhaust 1980 Corvette headers Thrush turbo mufflers (Drone pretty bad from 1600 to 2400 RPM) Brakes Rotors...stock Front 1980 BMW 320i Rear porsche 914 fronts 911 master cylinder proportioning valve replaced with t Ignition Distributor Stock HEI type Coil: Accel Plugs AC Delco CR43TS 100AMP alternator 1 wire Starter IMI high Torque Suspension Turbo Tie rods KB struts front Bilstien coil overs rear Front torsion bar 911 MOMO steering wheel Rims American Racing Tires 205 50 R 15 Falken estimated HP 325 Estimated torque 350 ft-lbs This was sent to me from the previous owner who did the re-build It also has a roll bar and racing seats set up for racing with camber 1.5 front and back Still getting used to the ride lots of power lots of fun thanks for any advice wow not one comment on list of upgrades?? Pretty standard v8 build,old school style. Should be a fun ride. |
1stworks |
Oct 16 2015, 10:07 AM
Post more "darkside" pictures (IMG:style_emoticons/default/beer.gif) Here's the slippery slope of 5 lug set ups: Those wheels are beautiful! |
whitetwinturbo |
Oct 16 2015, 10:15 AM
(IMG:style_emoticons/default/wacko.gif) (IMG:style_emoticons/default/wacko.gif) (IMG:style_emoticons/default/wacko.gif)
....you know when you are 'losing it'....when your wheels may be worth more than your sled..... |
Maltese Falcon |
Oct 16 2015, 10:49 AM
Nice shopping list on the sb 327.
I'm just wondering with mostly all good engine upgrades...why did the builder leave the low performance 1.94 heads; when this cam + 600cfm carb. will work so much better with the 2.02 heads? (IMG:style_emoticons/default/idea.gif) For these sturdy 4 bolt- main iron blocks I prefer the Chevy cam #3863151 hydraulic, 2.02 angle plug heads, roller rockers and pushrod guide plates. Nothing from China...all U.S. sourced parts (IMG:style_emoticons/default/flag.gif) |
Andyrew |
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
^^ So any modified honda owner?
Chris H. |
Oct 16 2015, 10:53 AM
Senior Member Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Hello All I will list the upgrades to this vehicle: 1968 Chevy 327 large main journal heads post 1987 Chevy 4 bolt stainless 1.94 intake 1.5 exhaust Camshaft Crane Cams??5840 hydraulic Clutch/Flywheel Kennedy Eng Products Stage III 9" KEP Stage III Pressure Plate KEP 228mm flywheel KEP Pilot/throw-out bearing Fuel MGT Intake Manifold Pro products "typhoon" Holly Carb 600 double pump Mr Gasket fuel pump Mr Gasket pressure reg 2 inline fuel filters K&N air filter Open System no thermostat 2 row aluminum radiator Ford Tarus SHO fan 2350 CFM 185 degree fan switch 1970 Dodge water-pump 440ci impeller Exhaust 1980 Corvette headers Thrush turbo mufflers (Drone pretty bad from 1600 to 2400 RPM) Brakes Rotors...stock Front 1980 BMW 320i Rear porsche 914 fronts 911 master cylinder proportioning valve replaced with t Ignition Distributor Stock HEI type Coil: Accel Plugs AC Delco CR43TS 100AMP alternator 1 wire Starter IMI high Torque Suspension Turbo Tie rods KB struts front Bilstien coil overs rear Front torsion bar 911 MOMO steering wheel Rims American Racing Tires 205 50 R 15 Falken estimated HP 325 Estimated torque 350 ft-lbs This was sent to me from the previous owner who did the re-build It also has a roll bar and racing seats set up for racing with camber 1.5 front and back Still getting used to the ride lots of power lots of fun thanks for any advice wow not one comment on list of upgrades?? Post more pics...that'll get the comments going. |
Bruce Hinds |
Oct 16 2015, 11:05 AM
Nice shopping list on the sb 327. I'm just wondering with mostly all good engine upgrades...why did the builder leave the low performance 1.94 heads; when this cam + 600cfm carb. will work so much better with the 2.02 heads? (IMG:style_emoticons/default/idea.gif) For these sturdy 4 bolt- main iron blocks I prefer the Chevy cam #3863151 hydraulic, 2.02 angle plug heads, roller rockers and pushrod guide plates. Nothing from China...all U.S. sourced parts (IMG:style_emoticons/default/flag.gif) I can't speak for the builder, but I did the same thing with mine because the slightly smaller valves allow a faster flow for a better mix of air and fuel and better burn. This was a big concern for me since I was building mine in Colorado where the air is much thinner. Even at lower altitudes unless you have high compression or are going to be running above 5500 rpm alot, there is little to no benefit from the bigger valves, they will actually not perform as well. At least that's what I've been told. Do we have an SBC experts out there that can comment? |
Lo-Fi Version | Time is now: 6th June 2024 - 01:59 PM |
