How to get quiet without a muffler, Exhaust Inserts....... |
john rogers |
Mar 14 2005, 10:24 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
Long ago when I raced Harley Davidson motorcycles we would drive them around on the street to tune and test them. We needed to quiet them down some and we used a steel multi disk insert with center tube which worked well. We would remove it to race. I just put one in each exhaust stinger on my 914 vintage six race car and they worked very well so hopefully I won't have to put the muffler on between races. An additional benefit is the cooler for the tranny sits right over the muffler and becomes a tranny heater, but no longer!! Available from Summit Racing and the 3 disk ones I bough were about $50 each.
scotty914 |
Mar 14 2005, 10:36 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
well i like my triad inspired exhaust i made for less than $75. if it is anything like triads for loss of hp, which it should be since he told me how to make it ( (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) triad dave ) i will have only lost about 6 hp, out 175 or so. and it sounds sweet and type 4 ish, even though its a suby.
but i almost went with the summit muffs with disks, but i wanted the balance between the cylinder banks |
Triaddave |
Mar 14 2005, 10:47 PM
Member Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 |
scott, did i read this wrong when you said a loss of HP ? usually you gain HP with the triad, (triad inspired).
scotty914 |
Mar 14 2005, 11:03 PM
sorry dave you did not mis read i mistyped, i meant a loss of 6 hp from an open exhaust, or a gain from a stock exhaust. and john if you want a sweet muffler set up with as little loss from your open pipes as you can get BUY a triad, and its even quite enough for daily driving. nothing like a gain over stock with a better sound. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
john rogers |
Mar 15 2005, 10:24 AM
Thanks for the info but I have a really good muffler, but I just do not want the hassle of having to switch it on and off. I am not currently doing any events that require any noise reduction so it is mainly for driving around and testing.
cha914 |
Mar 15 2005, 10:41 AM
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
John,
Do you have a summit part #? or what brand are they? I would like to run my stinger for an upcoming event and would rather not have to change exhausts at the event. How are they held in the stinger? Thanks, Tony |
Qarl |
Mar 15 2005, 10:58 AM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Try this...
Attached image(s) |
john rogers |
Mar 15 2005, 11:15 AM
Here you go. I had to modify them slightly as my stingers are tapered and these are for a straight pipe. I notched the front and back discs and expanded them slightly. I noticed that at idle the car was loud, but at 3500 RPM it was about as quiet as the muffler?
http://store.summitracing.com/default.asp?...t=egnsearch.asp |
Lo-Fi Version | Time is now: 3rd June 2024 - 11:16 AM |
