POR-15 Fail, Fuel Tank issues |
LowBridge |
Jan 4 2016, 03:30 PM
Member Group: Members Posts: 370 Joined: 10-August 15 From: Lunenburg, MA Member No.: 19,045 Region Association: North East States |
Anyone know how to fix this?
PO had it coated with POR-15 and it is now failing and I'm not sure why. (IMG:http://www.914world.com/bbs2/uploads_offsite/i219.photobucket.com-19045-1451942999.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i219.photobucket.com-19045-1451942999.2.jpg) I emailed the manufacture and they suggested buying a new POR-15 kit (IMG:style_emoticons/default/WTF.gif) and using aircraft grade stripper to remove old coating. thanks in advance... |
matthepcat |
Jan 4 2016, 03:51 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
The PO probably did not do a good enough surface prep before coating....or the tank was not completely coated well enough.
Older tank coatings also were not designed for ethanol fuels....could be an old coating. |
jd74914 |
Jan 4 2016, 09:11 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
No idea how to fix that besides hot tanking it or maybe knocking paint thinner around in it with some nails?
My experience with POR products have been lackluster at best, even with carefully prepped surfaces. If you are re-coating I would highly suggest using the epoxy kit by Caswell Plating. Myself and many others on the forum have used it and been very happy. http://www.caswellplating.com/epoxy-gas-tank-sealer.html Edit: Just read their website, Caswell suggests removing failed POR coating using a paint stripper containing Methylene Chloride. Be careful because MEK is pretty nasty stuff. |
aircooledtechguy |
Jan 4 2016, 09:37 PM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
POR-15 is great stuff *if*:
- Prep is done EXACTLY like the directions say ani i mean to the "T". - Absolutely no, and I mean NO water is left in the tank (seams are the culprit. (refer to #1) - A complete coating is made with no bare spots. I would consult the manufacturer about the issues you have. |
ConeDodger |
Jan 4 2016, 09:56 PM
Apex killer! Group: Members Posts: 23,605 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Bad prep... (IMG:style_emoticons/default/sad.gif)
74ravenna |
Jan 5 2016, 04:37 AM
Member Group: Members Posts: 471 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States |
I have to ask, why coat the tank at all? I guess the obvious reason is to protect it against corrosion.
I don't mean to hijack this thread but it seems i read about coating failure fairly regularly. Thats not a knock against the manufacturers of the coating, i'm sure its poor prep but how can we really be sure we've prepped the tank 100%? The seam that runs along the tank isn't visible after the baffle so how do you know its clean. Plus, the sock connection and the supply and return holes are another opening for fuel to get under the coating. Why not just keep a full tank of fuel with treatment and run it from time to time? Thanks Steve |
LowBridge |
Jan 5 2016, 05:59 AM
thanks for the ideas and comments and yes the fact that I have to use Methylene Chloride is the one thing that is worrying me.
I did not think about trying a hot tank, but I had thought about finding a plating company and seeing if they would dip the tank to clean it but not plate it. replacement tank just seems to be to expensive an option ($600) without trying other options first. |
mepstein |
Jan 5 2016, 07:20 AM
914-6 GT in waiting Group: Members Posts: 19,306 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I would just place a wtb and see if theris someone in your area with an extra tank. Even shipping isn't that expensive. The tanks are pretty small and light and fit easily into a rectangular box.
If your talking about AA's replacement tank, it's not new, just a cheaply redone tank. |
MJHanna |
Jan 5 2016, 07:23 AM
Does this 911 make my butt look big? Group: Members Posts: 805 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 |
Check with a radiator repair shop I had my tank hot vat and cleaned by a local shop. They were very reasonable on the cost.
BeemerSteve |
Jan 5 2016, 11:10 AM
Member Group: Members Posts: 239 Joined: 2-September 15 From: Van Zandt, Wa Member No.: 19,123 Region Association: Pacific Northwest |
Lo-Fi Version | Time is now: 1st June 2024 - 08:24 AM |
