brake calipers |
brake calipers |
RonnieJ |
Jan 8 2016, 12:41 PM
RonnieJ Group: Members Posts: 230 Joined: 16-June 03 From: Sterling Heights, Michigan Member No.: 829 Region Association: Upper MidWest |
Forgive me if this has been ask a thousand times but is there any alternative rear brake calipers I can install in replacement of the stock 914 rear calipers? Looking for something that is a direct replacement.
brant |
Jan 8 2016, 01:11 PM
914 Wizard Group: Members Posts: 11,638 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Forgive me if this has been ask a thousand times but is there any alternative rear brake calipers I can install in replacement of the stock 914 rear calipers? Looking for something that is a direct replacement. rebuilt 914 rear calipers... or ferrarri 308 rear calipers or 914/6 rear calipers its a unique parking brake set up you can change them and loose the parking brake or retain them and rebuild them, have a parking brake and pass state annual inspections. just call Eric... get pretty, basically like new ones from PMB who does the very best work and restores them to like new! |
pdlightning |
Jan 8 2016, 02:32 PM
Member Group: Members Posts: 207 Joined: 4-February 11 From: Santa Clarita Member No.: 12,660 Region Association: Southern California |
Forgive me if this has been ask a thousand times but is there any alternative rear brake calipers I can install in replacement of the stock 914 rear calipers? Looking for something that is a direct replacement. rebuilt 914 rear calipers... or ferrarri 308 rear calipers or 914/6 rear calipers its a unique parking brake set up you can change them and loose the parking brake or retain them and rebuild them, have a parking brake and pass state annual inspections. just call Eric... get pretty, basically like new ones from PMB who does the very best work and restores them to like new! I agree, go with Eric. He did mine and converted to the 308 style! (IMG:style_emoticons/default/piratenanner.gif) |
mgp4591 |
Jan 8 2016, 04:01 PM
914 Guru Group: Members Posts: 5,382 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
When I was performing State Inspections you had to have a mechanical parking brake. I was cruising through the regs the other day and it didn't say you couldn't have a hydraulic lock on your brakes instead of a mechanical. Maybe has to do with the new electric p. brakes some cars have?
Lo-Fi Version | Time is now: 7th June 2024 - 02:57 PM |
