914 RZ-1 |
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California ![]() |
I need to adjust the fore/aft position of my driver's side window. The car is a 72 but the door is a later one, as shown in the picture.
Do I/can I move the window forward? I'm thinking I need to take it out of the lift bracket and re-position it. Is there another way? I can't close the window all the way or it hits the roof. I can tell that it just needs to be pushed forward a bit. I tried tapping it with a rubber hammer to no avail. I loosened some bolts as well to see if that helped, to no avail. The Haynes manual was not much help. Any suggestions? Attached image(s) ![]() |
era vulgaris |
J is for Genius ![]() ![]() ![]() Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States ![]() |
Judging by your picture #2, your B-post is positioned fine and doesn't need to be moved.
In your picture #3, "C" is going to adjust how far up your window can travel, and "D" and "E" are going to allow you to adjust the tilt. You'll need to play with them. |
cpavlenko |
Member ![]() ![]() Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region ![]() |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
The bolts that attach the glass to the mechanism can be reached though the door when the window is in a specific position.
So, remove everything inside and then put the window handle back on and start rolling it down till you see the nuts in the openings of the door....hard to explain, but you can see them. Loosen them and slide the window forward. You may need to move that front pillar, it looks like the top is too far forward. That can be done with the top nut for the pillar loosened and the bottom nut used to angle the bar...both are movable. Now, the last part is tricky and may not make sense. The back top of the window when closed is controlled by both the front pillar, and the door angle itself. So the front pillar can be adjusted to a point, but it you go all the way and there is still a gap, you will need to back off the front pillar making the back of the window really far away from the car, and then adjust the door itself to angle the top of the door in. Once you tip the door in, start adjusting again. Rich |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,570 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Do I see a stainless guide on the front edge of your glass ? That does not belong on a late door, There should be a felty rubber guide inside the front column. Make sure you have the right column for a late door. If those parts are jumbled you'll have to fix that before adjustments can be made. |
914 RZ-1 |
So I consulted a friend and fellow 914er and he surmised, based on a thorough inspection, that I have a late model door with early model window, "B" pillar and triangle glass. That's what seems to be causing the problem.
Is the glass available from auto glass places? I guess I'll post a WTB ad for a "B" pillar for a late model door. |
rgalla9146 |
So I consulted a friend and fellow 914er and he surmised, based on a thorough inspection, that I have a late model door with early model window, "B" pillar and triangle glass. That's what seems to be causing the problem. Is the glass available from auto glass places? I guess I'll post a WTB ad for a "B" pillar for a late model door. See reply # 5 Unlikely you'll find door glass at an auto glass place. If you are reading this you are already at the best source All triangle glass is the same except for tint. Delour 1 or Sekurit 1 is non tinted , change the 1 to an F for tinted |
Lo-Fi Version | Time is now: 15th June 2024 - 07:48 PM |
