| 914Sixer |
Feb 16 2016, 05:50 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,433 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
I am trying to clean out all the spares I have. I have a choice of a good set of each type of heat exchangers. I like the light weight of the SSI but to me they do not sound as good as the stock one.
Right now I am leaning to the stock with a Dansk banana muffler. (IMG:style_emoticons/default/biggrin.gif) Any thoughts? |
| screenguy914 |
Feb 16 2016, 05:56 PM
Member ![]() ![]() Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
911 engine? If option A are early factory heat exchangers, there's little loss in choosing over the SSI versions (Option B). If option A are the post-73 type (single crossover), you would be giving up some power.
Sherwood |
| 914Sixer |
Feb 16 2016, 06:04 PM
Not a -6 engine. Bumped 75 2.0 L.
| EdwardBlume |
Feb 16 2016, 07:04 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
Tangerine. I know it's not an option but that's my answer.
| Bob L. |
Feb 16 2016, 07:09 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 851 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
From what I have read, the stock '75/6 2.0 exhaust is a bit of a dog.
The SSI's would be a better performance choice. |
| 914Sixer |
Feb 16 2016, 07:38 PM
OOPS I forgot to mention that I was using 73-74 2.0L stock heat exchangers NOT 75-76 ones.
| Tom_T |
Feb 16 2016, 08:18 PM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
OOPS I forgot to mention that I was using 73-74 2.0L stock heat exchangers NOT 75-76 ones. In that case Marc, the performance would be about the same, the sound is all in your ears & taste - so your choice (but hang onto the SSIs for back-up), but you'd have to watch for rust both inside & outside on the stock mild steel set so you don't CO (IMG:style_emoticons/default/icon8.gif) yourself. IMHO the new Dansk banana sounds the same as the OE ones did (except for the better flowing old Leistritz Sport version Banana, like the one sitting in my garage for my resto ;-) - plus you get a chrome tip with the Dansk! (on the tail-pipe - not you ;-) Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Lo-Fi Version | Time is now: 14th March 2026 - 06:51 AM |
