john914somers |
Member ![]() ![]() Group: Members Posts: 59 Joined: 24-January 12 From: sacramento Member No.: 14,051 Region Association: Northern California ![]() |
I'm researching fire extinguisher systems for my race car and I would like to know what people are using? What brand? Type? How many nozzles and why? How big? I see a lot of options out there and I'm uncertain which direction to go? There must be some sort of "certification, approval", agency/documentation one must have but I'm not sure. Thanks for your input!
ThePaintedMan |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States ![]() ![]() |
https://www.pegasusautoracing.com/group.asp...upID=FIRESYSSPA
This is what I went with. The AFFF foam is good stuff and won't corrode the car if it ever goes off. I went ahead and got the big bottle, despite the weight. I don't ever want to say, "wish I had gotten the bigger one and the driver (or car, to a lesser extent) might have survived." |
Bill's Racing 914 |
Member ![]() ![]() Group: Members Posts: 61 Joined: 2-March 14 From: Southern California Member No.: 17,064 Region Association: None ![]() |
Call Mark Goodman at Racing Fire Systems in Oregon Phone: 503 784-1878 e-mail: service@racingfiresystems.com
He has the best prices. For a 914, use a three nozzle Aqueous Foam system with a 3.375L bottle. Any bigger and you would most likely drown in the foam. On a 914, I recommend a nozzle pointed at the engine, one under the steering wheel pointed at you and one pointed at the fuel cel up front. I you were to add a fourth nozzle, I would have two nozzles in the engine bay, one pointed at each set of carbs. AN engine fire is going to come from a carb backfire, oil on the exhaust or a busted fuel line. If you have an engine fire, you do THREE things in this order....1. pull the fire handle....2. turn off the electrical kill switch...3. get the heck out of the car. You should be able to get to the kill switch from inside the car. Why?...to turn off the fuel pump. If you forget to turn off the kill switch, you might get to watch your car burn to the ground. I have seen this happen even though the driver dumped the fire system......nozzles are not always perfectly aimed to put out a fire. I also recommend two pull handles for the fire system. One on the center console for the driver to pull and one behind the driver for easier access for the flag workers to pull. This should be right next to the electrical kill switch so they can access both at the same time. They are trained (or at least they should be) to pull the fire handle and turn off the kill switch. Don't forget to mark both fire handles with a circle "E" sticker placed fairly close to them. When I am on the grid lined up with the other cars to go out on the track, I makes sure the corner workers and the fire crews know where the handles and the electrical kill switch are so there is no guessing at the last minute. Tell Mark it is for a 914 and he will set you up. |
Jetsetsurfshop |
Senior Member ![]() ![]() ![]() Group: Members Posts: 815 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States ![]() |
I used the same set up as George. I also put my outside fire pull and kill switch on the drivers side. Two reasons, if I managed to get out of the car and forgot to pull either one I don't have to run around the car and if the corner workers have to pull me out they car it helps them too.
I'll try to find a couple pictures. (IMG:style_emoticons/default/driving.gif) |
campbellcj |
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,631 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California ![]() ![]() |
I have the Spa 4L AFFF system with 4 nozzles: top of engine/carbs; top of fuel cell; driver's body; and footwell.
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,008 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
if you go with halon (or halotron)
Do NOT put a nozzle in the cockpit you can suffocate and pass out in the car happened to friend of mine and luckily he only had minor burns when his friends pulled him (unconscious) out the window of a 914/6 that burned to the ground. he pulled the release pin and passed out before he could crawl out of the car. |
Cracker |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States ![]() ![]() |
I'm late to this discussion but here is what I ultimately decided upon. I started looking at the "Safecraft" products due to Marty's window net pic in his build. One thing led to the next and I've gone 100% Safecraft for all of my safety gear. I chose the LE5 electric system for my fire bottle system. The quality and fit/finish was impressive to me. I'll post pictures eventually, once the system is installed. I found the best deal and descriptions on a website called "Winding Road" - FWIW.
Tony |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
I have a Firecharger refillable system with three nozzles: One on the fuel cell, one above the engine pointed at the carbs, and one below the steering wheel pointed at the driver's crotch.
The pull handle is right next to the Driver's side rear-view mirror so I can reach it as well as any track workers. Then I ALSO have a halotron 2.5 lb extinguisher on the center console next to the driver. |
john914somers |
Thanks guys for the great information! I ended up going with Mark Goodman's advice, which was a 4 lb, 6 nozzle system. He is a really knowledgeable, helpful guy and I would recommend him! Thanks again!!!
Lo-Fi Version | Time is now: 2nd July 2025 - 11:12 PM |
