Hockey Puck Hardware |
e_artiles |
Feb 25 2016, 10:34 PM
Member Group: Members Posts: 76 Joined: 14-February 12 From: Corona, CA Member No.: 14,131 Region Association: Southern California |
I just bought the Hockey Puck Horn Base from Mark and on his site it says that it uses 3/32" hardware. I can't seem to find the right hardware at my local box store. Has anyone installed this and if so, what size hardware did you use?
Mikey914 |
Feb 25 2016, 10:41 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Sorry, my initial response I was thinking about the steering linkage puck. You can get them at any ACE hardware. Shoot me the length (of the OEM) again and I can pick some up to add to these.
porschetub |
Feb 26 2016, 02:40 AM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Sorry, my initial response I was thinking about the steering linkage puck. You can get them at any ACE hardware. Shoot me the length (of the OEM) again and I can pick some up to add to these. I carefully ran the metric screws in and they cut new threads in the brass inserts no problem,go slowly all will be good,I think to stock screws are like 4mm from memory. |
e_artiles |
Feb 26 2016, 08:31 AM
Sorry, my initial response I was thinking about the steering linkage puck. You can get them at any ACE hardware. Shoot me the length (of the OEM) again and I can pick some up to add to these. I carefully ran the metric screws in and they cut new threads in the brass inserts no problem,go slowly all will be good,I think to stock screws are like 4mm from memory. I'm a bit confused. Is there an insert that goes into the horn button base first? |
porschetub |
Feb 26 2016, 11:57 AM
Sorry, my initial response I was thinking about the steering linkage puck. You can get them at any ACE hardware. Shoot me the length (of the OEM) again and I can pick some up to add to these. I carefully ran the metric screws in and they cut new threads in the brass inserts no problem,go slowly all will be good,I think to stock screws are like 4mm from memory. No I was mentioning the fastenings that are moulded into the plastic of the button ,there is 3 of them. You mount all the hardware off a stock horn button on to them,or buy a kit/parts from various vendors,can't remember if 914rubber has a kit but SMC do. |
Mueller |
Feb 26 2016, 01:08 PM
I just bought the Hockey Puck Horn Base from Mark and on his site it says that it uses 3/32" hardware. I can't seem to find the right hardware at my local box store. Has anyone installed this and if so, what size hardware did you use? Someone needs to learn how hardware is spec'd (IMG:style_emoticons/default/smile.gif) (914rubber, not you) Looking at my charts, that number makes no sense. Is it supposed be 6-32 or 8-32? 3/32" = .09375 diameter, the closest I see is a #3 screw which is available in 3-48 or 3-56 |
SirAndy |
Feb 26 2016, 01:17 PM
Resident German Group: Admin Posts: 41,677 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
3/32" = .09375 diameter, the closest I see is a #3 screw which is available in 3-48 or 3-56 (IMG:style_emoticons/default/wacko.gif) I am soooo glad i grew up with the metric system ... (IMG:style_emoticons/default/cheer.gif) |
e_artiles |
Feb 26 2016, 06:34 PM
So which size screw is used for the horn button replica that 914Rubber sells?
wndsnd |
Feb 26 2016, 06:59 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
I just bought the Hockey Puck Horn Base from Mark and on his site it says that it uses 3/32" hardware. I can't seem to find the right hardware at my local box store. Has anyone installed this and if so, what size hardware did you use? Someone needs to learn how hardware is spec'd (IMG:style_emoticons/default/smile.gif) (914rubber, not you) Looking at my charts, that number makes no sense. Is it supposed be 6-32 or 8-32? 3/32" = .09375 diameter, the closest I see is a #3 screw which is available in 3-48 or 3-56 Seems natural 356 would be the Porsche choice. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 02:53 PM |
