Why does right tire rub fender only in reverse? |
Jason74914 |
Mar 7 2016, 11:31 AM
Member Group: Members Posts: 76 Joined: 9-January 16 From: Dallas Member No.: 19,544 Region Association: None |
I'm running 195's on my car and I did have to roll the inside lip of the rear fender for clearance. No problem moving forward, but on occasion when I'm backing up, the driver side rear tire will still rub the fender lip. I'm guessing this is just because in reverse it "torques" the tranny. (This is the second 914 I've had, and the first one did the same thing.)
Any way to fix this? Thanks. |
914forme |
Mar 7 2016, 11:36 AM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
My guess is suspension bushings. This allows toe-change and when backing up forces the tire out to rub. By chance does it happen while turning.
Tranny movement is completely separate of this, and if it isn't you have way bigger issues. |
StratPlayer |
Mar 7 2016, 11:58 AM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
There is a thread on here about a tire rub kit! I think it is sold by restoration. Design! It seems to be common problem with the 914.
Here's the link for the tire rub kit, it's not restoration design: http://www.elephantracing.com/suspension/t.../914tirerub.htm |
914_teener |
Mar 7 2016, 12:01 PM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
My guess is suspension bushings. This allows toe-change and when backing up forces the tire out to rub. By chance does it happen while turning. Tranny movement is completely separate of this, and if it isn't you have way bigger issues. (IMG:style_emoticons/default/agree.gif) Jack the rear of the car up....grab the tire and see if you can make it "rack". |
rfinegan |
Mar 7 2016, 12:05 PM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
My 75 did this with 195 too, I never found a root cause but put 100 LB springs in the rear and I no longer have this issue. Please post your progress for those who need to know...
Best of luck -Robert |
brant |
Mar 7 2016, 04:18 PM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I'm going with bushings (spell check strikes again)
or an ovaled console hole |
Larmo63 |
Mar 7 2016, 10:27 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
SirAndy |
Mar 7 2016, 11:15 PM
Resident German Group: Admin Posts: 41,679 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
r_towle |
Mar 7 2016, 11:18 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Or a rusted and kinda broken suspension console.
Don't drive it till you jack it up and know why it is doing this....it might be bad. |
EdwardBlume |
Mar 8 2016, 02:06 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
(IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) |
DBCooper |
Mar 8 2016, 06:08 PM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
My bet is also suspension bushings. If moving the car by hand doesn't work you can re-create the movement. Have someone in the car put it in first gear with their right foot firmly on the brake and at a fast idle let the clutch out until it's slipping. You'll see some movement as the drive train "jacks up" against the stationary rear wheel. Then put it into reverse and do the same, you should see the tire move into contact with the fender. Don't get underneath the car or anywhere where you could be hurt, but have your friend go back and forth between first and reverse and you should be able to see what's moving and where.
914forme |
Mar 8 2016, 08:49 PM
(IMG:style_emoticons/default/agree.gif) But it sounds like a good use of a gopro or equal camera.
Lo-Fi Version | Time is now: 10th June 2024 - 08:47 AM |
