Boxster Tranny and axles. |
spaceshuttle |
Mar 7 2016, 12:55 PM
Member Group: Members Posts: 73 Joined: 25-November 06 From: SouthCarolina Member No.: 7,258 |
Hey y'all, i know someone here is using the 5 speed boxster tranny on their 914. Which axles did you use and what will I run into. Lengths?
As I said it is a 5 speed from a 2003. NOT a 6 spd S. TIA LC |
Andyrew |
Mar 7 2016, 02:42 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
What engine and are you making your own cradle?
Mike Bellis is also using this trans and the 6 speed. I made my own engine cradle to put the trans in the very center (For my 1.8T conversion) 100mm stub axles from a boxster or a late AWD audi. VW Bus axles 18 3/4" long (clip to clip) 914 outer stub and 100mm adapters from renegade hybrids. The axles still have 1-1.5in of play in them so there wont be any binding. Mind you I had to move the trans mount over on the body to fit my custom shifter setup. All details and pics in my build thread. |
spaceshuttle |
Mar 8 2016, 10:29 AM
What engine and are you making your own cradle? Mike Bellis is also using this trans and the 6 speed. I made my own engine cradle to put the trans in the very center (For my 1.8T conversion) 100mm stub axles from a boxster or a late AWD audi. VW Bus axles 18 3/4" long (clip to clip) 914 outer stub and 100mm adapters from renegade hybrids. The axles still have 1-1.5in of play in them so there wont be any binding. Mind you I had to move the trans mount over on the body to fit my custom shifter setup. All details and pics in my build thread. Thanks Andy. I have a set of the Renegade axles that I will try. Mating the tranny to a SBC. I already have an adapter plate for a Boxster S from Kennedy. I will have to modify the starter pocket on the non S Boxster tranny a little to make it work. It's going in my Tubeframe car, so we'll just fab a cradle as necessary. Thanks Again |
Mueller |
Mar 8 2016, 10:43 AM
What engine and are you making your own cradle? Mike Bellis is also using this trans and the 6 speed. I made my own engine cradle to put the trans in the very center (For my 1.8T conversion) 100mm stub axles from a boxster or a late AWD audi. VW Bus axles 18 3/4" long (clip to clip) 914 outer stub and 100mm adapters from renegade hybrids. The axles still have 1-1.5in of play in them so there wont be any binding. Mind you I had to move the trans mount over on the body to fit my custom shifter setup. All details and pics in my build thread. Thanks Andy. I have a set of the Renegade axles that I will try. Mating the tranny to a SBC. I already have an adapter plate for a Boxster S from Kennedy. I will have to modify the starter pocket on the non S Boxster tranny a little to make it work. It's going in my Tubeframe car, so we'll just fab a cradle as necessary. Thanks Again And the link to your build is where? (IMG:style_emoticons/default/smile.gif) |
spaceshuttle |
Mar 8 2016, 12:29 PM
What engine and are you making your own cradle? Mike Bellis is also using this trans and the 6 speed. I made my own engine cradle to put the trans in the very center (For my 1.8T conversion) 100mm stub axles from a boxster or a late AWD audi. VW Bus axles 18 3/4" long (clip to clip) 914 outer stub and 100mm adapters from renegade hybrids. The axles still have 1-1.5in of play in them so there wont be any binding. Mind you I had to move the trans mount over on the body to fit my custom shifter setup. All details and pics in my build thread. Thanks Andy. I have a set of the Renegade axles that I will try. Mating the tranny to a SBC. I already have an adapter plate for a Boxster S from Kennedy. I will have to modify the starter pocket on the non S Boxster tranny a little to make it work. It's going in my Tubeframe car, so we'll just fab a cradle as necessary. Thanks Again And the link to your build is where? (IMG:style_emoticons/default/smile.gif) Didn't do a build page but there are pics of the car over on the race car photo thread towards the end. |
Mike Bellis |
Mar 8 2016, 08:56 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I run one 19.25" and one 20.25". The differential is offset to one side. Best prices are at Pacific Customs. If you call them, they will sell single axles for about $110 each. I'm also running 930 CV's and 28 spline axles. Renegade axles are Bus T2 units with 33 splines.
http://www.pacificcustoms.com/porsche-930-...moly-axles.html |
914forme |
Mar 9 2016, 01:49 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Thank you Mike, just saved some dough on my build (IMG:style_emoticons/default/beer.gif)
Lo-Fi Version | Time is now: 10th June 2024 - 04:18 AM |
