turk22 |
Treetop Flyer ![]() ![]() ![]() Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest ![]() |
I found that my AAR appears to stuck closed, very poor cold idle, and then idles fine after warm up. I plan to PB blaster the crap out of the AAR and bench test it to make sure it can open and close correctly.
This may be a stupid question, but how is this lead disconnected, is it simply pulled off, or ?? ![]() ![]() thanks, Turk |
913B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 863 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None ![]() |
You don't want to take the wire off it is soldered to the other leg of the internal heating wire. Just leave it alone and be sure to place that heat shrink or additional tubing to prevent that wire from bending too much and shorting out. From my experience soaking it with PB didn't help for me. If you are capable of uncrimping the top portion and then soak it and manually turn it until it's free. It's not that hard, it won't look too pretty afterwards but it will work very smoothly. Good luck
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,977 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Just disconnect the other end of that red wire where it connects to the ignition harness.
era vulgaris |
J is for Genius ![]() ![]() ![]() Group: Members Posts: 983 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States ![]() |
Been a while now since I had my djet car, but IIRC there is a plastic connector somewhere in the vicinity of the underside of the plenum. But maybe I'm thinking of something else. I can't recall right now how I removed mine, it's been a couple years. It's possible I cut it and re-soldered it together. Trace the wire to where it meets the loom and see if you find a connector somewhere along the way.
BTW, I soaked mine in a bath of WD40 for a couple days. After that it worked perfectly. |
pilothyer |
Member ![]() ![]() ![]() Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States ![]() |
I have found that in addition to the PB Blaster soak, you need to let it cool down and open, insert a small screw driver while it is open, then heat it up and it will try to close..........use the screwdriver to open it to maximum and then remove the screwdriver in such a way as to make the valve "Slam Shut" after a few cycles the carbon will be broken up and the valve will fully close as it should as it heats up.
turk22 |
ok, I see the connection on the other end. I'm guessing this is covering a spade connection? I don't see an obvious way to open this up, but the little bit of blue I see, looks like a simple crimp connection
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,204 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Correct, it's just a spade connection.
--DD |
PlantMan |
Member ![]() ![]() Group: Members Posts: 438 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California ![]() |
I just rebuilt my AAR as it was stuck open too. I PB soaked it too, several times, but ultimately had to crack it open and clean it out that way. After I opened it I realized that it was really rusted open. After some work it broke free.
Yours may come to that too but the whole process can be done in a couple hours. the hardest part is getting the thing open. Enjoy! |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,781 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
That blue collar is a crimp-on replacement connector.
It might not survive removal. Solder a replacement on there. |
turk22 |
can I use a battery tender to apply the 12v needed to bench test the AAR, or even a 12v Cordless drill battery?
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Any 12 VDC source will do, but it has to have enough amperage. I use a battery charger. Red is positive ....... the shell of the AAR is ground.
It get constant 12 VDC as long as the key is on. The red wire on the AAR connects to the white wire in the engine harness. |
turk22 |
thanks I'll test it that way
jack20 |
Member ![]() ![]() Group: Members Posts: 422 Joined: 7-November 14 From: Granite Bay, CA Member No.: 18,099 Region Association: Northern California ![]() ![]() |
I had the same problem with mine. I soaked it in wd40 for two days and then hooked it up to a spare motorcycle battery. It worked. I tried a battery tender before hand and it wasn't up to the task. Give it some time to soak and flush well before tearing into it.
turk22 |
very successful clean and test of the AAR, after flushing it out multiple times, and letting ist soak, and cycling from the freezer to the bench hooked up to the battery charger, I could watch it go from full open to full closed and back. When closed I verified that it would not pass any air.
Once I re-installed it, I had a much higher cold idle, which is what I was really lacking. I also had to chase the warm idle a bit, by adjusting the bleed screw, and making sure one of the vacuum lines was tightly sealed. Chasing idle issues is a blast! If I keep telling myself that, I"ll start to believe it. (IMG:style_emoticons/default/bs.gif) |
Lo-Fi Version | Time is now: 16th July 2025 - 04:41 PM |
