> Buying a lift, need some suggestions
stags14
post Mar 24 2005, 02:13 PM
Meep Meep Meep Meep Meep!!!
Going to be buying a lift. I am splitting the cost 3-ways (My Dad, my Brother-in-law, and me). I am on a fact finding mission to find something suitable at a "decent" price.
I saw the following on e-bay? Thoughts on this one:
ebay lift
Any other recommendations?
Stags
lapuwali
post Mar 24 2005, 02:15 PM
Not another one!
This has been discussed extensively. Do a search, and you'll find at least four threads on the topic.
greglepore
post Mar 24 2005, 03:17 PM
Bought the 10k version of that lift recently. Nice enough-frame appears to be fab'd in China, hydraulic pack is domestic. You'll need either a forklift/skidsteer or have it delivered to a terminal and pick it up w/ a trailer.
Works well, no issues. Took a day to install/wire/adjust equalizing cables. No complaints.
rhodyguy
post Mar 24 2005, 03:40 PM
what's the dif between the $10k model and the one listed? other than the money?
k
Gint
post Mar 24 2005, 06:37 PM
Mike Ginter
I had my 4 post shipped to and held at the truck depot and went there to pick it up. They loaded it via forklift on my trailer. When we got it to the house, we just unpacked it from the trailer and took the pieces into the garage. Worked well and I didn't have to have a bunch of guys (or a forklift) waiting around for a truck for a full day.
Mueller
post Mar 24 2005, 06:50 PM
914 Freak!
QUOTE (rhodyguy @ Mar 24 2005, 02:40 PM)
k
10K - 7K = 3K (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
K=thousands, as in pounds for this case........
Joe Bob
post Mar 24 2005, 07:32 PM
I bought the Direct Lift, 1800 installed....has four posts and ramps....extra four hundred got me the ramp sliding hand pump pnuematic jack.....connects to the axles and lifts the car off the ramp.
mk114
post Mar 30 2005, 01:10 AM
LOST in NO space (my garage)
well if you need a lift I am your man have worked for a lift company for 11 years and can give all relative info
need dims of you shop how wide how long how tall
do you need it installed
what are looking for pad lift, two post, four post
MecGen
post Mar 30 2005, 05:31 AM
8 Easy Steps
Hi MK114
Got a question for you, what is the min ceiling requirement.? Here its @12 feet, sounds about right ?
Regards
Joe
(IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
914forme
post Mar 30 2005, 06:16 AM
http://www.914world.com/bbs2/index.php?act=...&hl=2+post+lift
Just a short list there are about 6 of them
Clay has a really nice 2 post lift, one thing I found was that they all will leave someing out of the package - having helped install two of them from 2 different manucatures. Both where short something, a bolt or two, one was an arm??????
But check your package, and get all the pieces in place.
1bad914
post Mar 30 2005, 06:27 AM
I am contemplating putting one in my garage, but I have drains, the floor is slanted for the drains, would I have to build up cement pads on the low sides, if so, would it take special concrete or could I build a form and use quick-crete, probably a fiber filled condrete from the crete guy, Answered my own question. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) The price on this seemd much cheaper than I have seen before! I likey!
John
post Mar 31 2005, 12:23 AM
member? what's a member?
I like our two post, asymetric lift. It was bought 10 years ago and has been absolutely trouble free.
My lift, unlike the one shown on the ebay link, has nothing on the floor between the two posts. The hydraulic lines and safety latches go overhead and tie the tops of the two columns together as well as provide a shut-off if the vehicle roof nears the crossbar/ceiling.
It was $3,500.00 brand new, installed and most importantly MADE IN USA....
It's an 8,000 lb Rotary Lift. I like it very much. I've had our full sized Suburban up on it.
Now, I just need an alignment rack/lift.... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
mk114
post Mar 31 2005, 01:30 AM
most lifts require 12'1'' ( I know its wierd but 12'1") and 12 foot wide is right for space too
mk114
post Mar 31 2005, 01:35 AM
rotary is a good hoist I used to sell them . A good hoist sells for 2600 plus 300.00 installed (usually doesn't have electrical hook up) which just 230v single~
MecGen
post Mar 31 2005, 05:54 AM
8 Easy Steps
Can you explain
is this an added option? I was looking just for this.
Regards
Joe
mk114
post Mar 31 2005, 12:41 PM
what I mean is mos lifts sit at12'1" (there are some that don't but 12'1" is what I looked for when installing a hoist) I have a pad lift myself ( raises to about 34") it works ok I had a alignment rack but it was to bulky (took up to much room) A good two post will do everything you need to do
greglepore
post Mar 31 2005, 03:23 PM
The ebay lift is available in two configurations; the normal is 12' 1, the low is something like 9'6-it has a broader footprint to compensate. The downside of the ebay lift is that the safety catches aren't integrated together, so you need to walk over to the far side of the car to release a catch before you lower.
MecGen
post Mar 31 2005, 05:21 PM
8 Easy Steps
I thought you ment you had a sensor or a lite beam that turns off the lift when it getts too close to the ceiling
This would be cool, I am sure its out there, or can be made.
Thanks for the info
Regards
Joe
914werke
post Mar 31 2005, 07:04 PM
Are ther such things as single post lift?
mk114
post Mar 31 2005, 07:41 PM
yes but they are inground usually cost about 8000 to install
I have see above ground but don't trust them due to stabillity
- Lo-Fi Version Time is now: 16th July 2025 - 04:58 PM
