1.8, AFM |
1.8, AFM |
mtndawg |
Mar 28 2016, 06:09 PM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
$20 plus shipping.
Attached thumbnail(s) |
jim_hoyland |
Mar 30 2016, 07:06 AM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
6 wire or 7 wire plug ?
bdstone914 |
Mar 30 2016, 08:38 AM
bdstone914 Group: Members Posts: 4,536 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
6 pin, had one with the same number sitting here. Correct for a 1974 1.8L 914 only.
Good price if it works. Should pop the cap off and inspect the circuit board for wear. Bruce |
74ravenna |
Mar 30 2016, 10:03 AM
Member Group: Members Posts: 471 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States |
6 pin, had one with the same number sitting here. Correct for a 1974 1.8L 914 only. Good price if it works. Should pop the cap off and inspect the circuit board for wear. Bruce I just checked my the other day at the pins and had the correct readings but I had no idea that a visual inspection should be done. May be obvious to most folks here but what am I looking for in the inspection you describe. Thanks. |
mtndawg |
Mar 30 2016, 11:41 PM
That's right it's for 6 wire. I don't know how to check for wear on this thing. It's an extra part that came with a car I bought.
jim_hoyland |
Mar 31 2016, 08:45 AM
That's right it's for 6 wire. I don't know how to check for wear on this thing. It's an extra part that came with a car I bought. From my experience; flapper has to move freely, and there are a couple of continuity tests that are done between the pins. I don't have the acceptable ranges, but they have been posted |
orthobiz |
Mar 31 2016, 03:08 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
timothy_nd28 can probably tell you any and everything you need to know about these!
Paul |
Lo-Fi Version | Time is now: 8th June 2024 - 06:31 AM |
