stock 2.0 1973-74 engine which pertronix ? |
dflesburg |
Apr 10 2016, 06:56 AM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
working on a stock 73 - 74 2.0
Pelican sells like 5 different versions of the pertronix ignitor which one do buy? Thinking either the 1 for $80 or the 2 for $112 |
76-914 |
Apr 10 2016, 08:12 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
It used to be P834V but IIRC they have a newer one that won't fry if you leave the ign switch on too long. Buy 2 so you can keep a spare on board. (IMG:style_emoticons/default/beerchug.gif)
dflesburg |
Apr 10 2016, 08:56 AM
It used to be P834V but IIRC they have a newer one that won't fry if you leave the ign switch on too long. Buy 2 so you can keep a spare on board. (IMG:style_emoticons/default/beerchug.gif) ???? ----can you please restate the answer? |
iankarr |
Apr 10 2016, 09:13 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Go with the II.
Great advice to get a spare. Pertronix is more consistently reliable than points, but since they're digital, when they die, the die immediately. Not like points where the engine runs progressively worse, but you at least have time to fix it without being stranded. But they do last. I've had a III on my 65 mustang for 5 years and it works great. |
colingreene |
Apr 10 2016, 02:29 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
Every pertronix part ive ever used sucked.
I run points for a reason. My dads car hated it. Mine hated it. The bmw race car we run also gave us trouble. Pertronix warrantied them but it was still beyond anoying to deal with. |
Bulldog9 |
Apr 10 2016, 09:30 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
I would go with ignitor 2, has auto shut off protection, and a progressive dwell. Make sure you match the correct coil. I think the Ignitor 2 has a .06 ohm rating. They sell it in epoxy and oil filled. Check out european motorworks, but many other vendors sell as well.
PancakePorsche |
Apr 10 2016, 10:04 PM
Member Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
I would go with ignitor 2, has auto shut off protection, and a progressive dwell. Make sure you match the correct coil. I think the Ignitor 2 has a .06 ohm rating. They sell it in epoxy and oil filled. Check out european motorworks, but many other vendors sell as well. (IMG:style_emoticons/default/agree.gif) coil matters indeed !. I never had problems with these. Best upgrade you can do to your dizzy. |
Lo-Fi Version | Time is now: 3rd June 2024 - 09:21 AM |
