Two quick L-Jet questions |
Rob-O |
Apr 18 2016, 10:39 AM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Doing some initial refitting as I go back to L-Jet.
Question #1: Are there supposed to be any gaskets between the head and the intake manifold OTHER than the roughly 10mm thick phenolic gasket? I ask because the carb set up I pulled off had both metal gaskets and cardboard-ish gaskets. Question #2: Trying to determine the correct orientation of the oil filler neck. Does the vacuum hose fitting point towards the passenger compartment firewall? Or towards the rear of the car? See pictures. Attached thumbnail(s) |
orthobiz |
Apr 18 2016, 10:42 AM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
Oil filler vacuum hose points to the rear.
Pau |
jim_hoyland |
Get that VIN ? Group: Members Posts: 9,314 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Oil port point to the rear; a hose will join the FI boot. Be sure it seals, a vacume leak hear will be a problem
Manifold only uses a thick phenolic spacer/gasket |
r_towle |
Apr 18 2016, 03:37 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
L-jet is very sensitive (won't run right) to vacuum leaks.
So, at the manifold gaskets, a paper covered phenolic spacer, and I use a thin covering of liquid gasket (copper) on both sides of that spacer.... You need to be super detailed in assembly to ensure no leaks. Make sure you have both the gasket and o ring in the oil filler cover... The vent line faces the intake manifold on the engine, not away from it. |
jim_hoyland |
Apr 18 2016, 04:25 PM
L-jet is very sensitive (won't run right) to vacuum leaks. (IMG:style_emoticons/default/agree.gif) In addition; use new hoses and replace any T connectors. I've had T-connectors crack and cause leaks as well as hose' ( especially the small ones ) get real brittle and slowly break apart. An air leak will become apparent when the engine rpms seems to hunt at idle; up then down. In any case, it's critical..... Good luck with the reinstall (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smile.gif) |
Rob-O |
Apr 19 2016, 07:55 AM
Thanks for the replies, gentleman.
I've got new manifold gaskets, new vacuum hoses and a ton of other stuff coming from Pelican. Sent the injectors to WitchHunter and expect the TB back from Phil Eslin any day now (there is a recent thread on his TB restorations). The only vacuum hose I'm reusing is the one from the oil filler to the elbow between the AF meter and the TB. But I've cleaned that one up and inspected it thoroughly. I also have some hose clamps to make sure it's getting a good seal. Good idea on the copper sealant, I'll pick some up today. I've checked the heads and removed any of the old carb gaskets. The intake runners were powder coated. Not where the manifold meets the head however. That part was lightly bead blasted to remove any crud. I'll put a proper thread together once I start assembly. Oh, and I've got Clay Perrine in the wings who will be helping with install when I get to that point. Hopefully in the next week or two. Now I'm off to check continuity on the FI harness and the engine harness. |
Rob-O |
Apr 19 2016, 07:59 AM
Forgot to add that I have and installed a new O-ring on the oil filler cap. Also a new cork gasket at the bottom of the filler assembly. The seal at the top of the cap is on back order from Bug Depot. If it does t get here soon I'm sure I can find one sourced locally from Zims.
Lo-Fi Version | Time is now: 3rd June 2024 - 08:24 AM |
