901 Regear |
901 Regear |
frankiec@outrageous.net |
Apr 18 2016, 02:11 PM
Member Group: Members Posts: 81 Joined: 31-March 13 From: Mendocino, CA Member No.: 15,717 Region Association: Northern California |
I have a 914 with a 3.2 in it. It has a 901 side shifter 4cyl transaxle so the gearing is such that I'm using the tranny as a 4 speed, starting in 2nd. This works OK and is fun in some situations but I'd like to get gearing that suits the 3.2 as I'm a back roads kind of guy and take the occasional cruise. I checked with some shops and to regear my gearbox seemed (I'm not being critical of the amounts per se) a bit high for my budget. The cost was in the 2K range. A thought I had was to get a 901 transaxel from a 911 that would be close to what I want for gearing. Anyone out there done this? Cost? Time?
Correct year transaxle? Thanks, Frankie |
Mark Henry |
Apr 18 2016, 03:00 PM
You can regear, get a higher 5th, but it will still be a 4 speed with a granny gear.
You start using 1st gear hard with a 3.2 and your tranny won't last very long. I'll be using A, F, O, X, HB |
r_towle |
Apr 18 2016, 03:12 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I never use 1st in the 3.2 911 unless I am at a complete stop.
If it really does not work for you, get a 915 tranny from a 911 and flip the diff, there are kits out there for this. Rich |
Mark Henry |
Apr 18 2016, 03:17 PM
If it really does not work for you, get a 915 tranny from a 911 and flip the diff, there are kits out there for this. Rich Not for a $2K budget. (IMG:style_emoticons/default/shades.gif) |
brant |
Apr 18 2016, 03:27 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
If it really does not work for you, get a 915 tranny from a 911 and flip the diff, there are kits out there for this. Rich Not for a $2K budget. (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/agree.gif) |
r_towle |
Apr 18 2016, 03:32 PM
The solution to his issue won't match his budget.....at least today
AZ914 |
Apr 18 2016, 04:10 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
I have an X gear (4th) and a flipped H (5th) in my 3.2 1st is worthless. This 5th is a great freeway gear.
You could check with member Dr. Evil as he does trans work to see if its more affordable than your local shop. You can always just send him the gear stack (instead of the entire unit) if you don't want to do the work yourself. |
toolguy |
Apr 18 2016, 06:23 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Just a thought before you make 5th longer. . the reason the factory used a ZA for the 6 vs the ZD in the 4 cylinder engine was associated with engine cooling. . They determined 'somehow' that the Six needed to turn more RPMs for best efficient engine cooling from the fan at highway speeds. . granted a 3.2 won't be working as hard as a 2.0 so maybe it's a toss up. . Just a thought.
As far as changing gear sets, you can do it with the trans in the car but lowered at the rear. . cuts work effort and should cut costs but I'd wonder if a shop would tell you that. . |
PanelBilly |
Apr 18 2016, 06:38 PM
914 Guru Group: Members Posts: 5,811 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Or save up the $ and get the gears that you want.
r_towle |
Apr 18 2016, 06:46 PM
Lo-Fi Version | Time is now: 3rd June 2024 - 07:53 AM |
