Gas tank dripping, seals missing? |
Chris914n6 |
Apr 20 2016, 10:42 PM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Seeping out of both nuts. Besides the stainer, is there supposed to be a seal of sorts?
What are my options? I have places to be in a week (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/piratenanner.gif) |
Mikey914 |
Apr 20 2016, 10:45 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Should be a seal between the tank and expansion tank. No seal on the top of the expansion tank. only metal flange.
http://shop.914rubber.com/searchquick-subm...words=expansion |
Chris914n6 |
Apr 20 2016, 11:02 PM
I'm talking about the outlets on the bottom of the tank.
Expansion tanks add weight (IMG:style_emoticons/default/laugh.gif) But thanks for the quick response (IMG:style_emoticons/default/beer.gif) |
Mikey914 |
Apr 20 2016, 11:04 PM
Yes, there is a thread here somewhere about copper washers if I recall correctly.
Rotary'14 |
Apr 20 2016, 11:12 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
There are fiber washers that act as seals. You should not use copper as you will get an electrolytic reaction between the two metals.
Mikey914 |
Apr 21 2016, 12:02 AM
There are fiber washers that act as seals. You should not use copper as you will get an electrolytic reaction between the two metals. Yep, makes perfect sense. Anyway, there was a thread here. Pretty sure Crusty sent me a bunch at one time, but I don't know where they went. Sorry. Probably why I remembered this subject. |
Rotary'14 |
Apr 21 2016, 06:16 AM
PM me your address and I can get you some.
74ravenna |
Apr 21 2016, 06:36 AM
Member Group: Members Posts: 471 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States |
Hi,
I'll be disconnecting my tank again this weekend to replace my feed line washer. What are peoples thoughts on pipe sealant when putting it back together? I have a can of pipe dope rated for gasses, chemicals, gasoline, even jet fuel. Its rated at 10,000 psi (way more than I need I know). Thanks in advance. |
bdstone914 |
Apr 21 2016, 07:40 AM
bdstone914 Group: Members Posts: 4,533 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Hi, I'll be disconnecting my tank again this weekend to replace my feed line washer. What are peoples thoughts on pipe sealant when putting it back together? I have a can of pipe dope rated for gasses, chemicals, gasoline, even jet fuel. Its rated at 10,000 psi (way more than I need I know). Thanks in advance. Do not use any sealant on the gas tank fittings. It is a flat sealing surface. They seal with a fiber washer. Remove the tank and hone flat the threaded nipples on the tank. The sealing surface is only 1mm wide. Get a new filter sock. Note the orientation of the nipples before removing them. It is trick to route the rubber hoses from the nipples without kinking the rubber hose. I once installed a tank and could not get it to not drip. Had to remove the tank and hone flat the surface to stop the leak. Bruce |
76-914 |
Apr 21 2016, 08:48 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/agree.gif) Pipe dope will help to seal tapered ips threads. Otherwise it is just a lubricant.
rhodyguy |
Apr 21 2016, 10:12 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,085 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
You should consider replacing the in tank screen ( or at least have one on hand) when you have the tank out. Robert should have one. Plan on flushing the tank too.
Lo-Fi Version | Time is now: 3rd June 2024 - 06:25 AM |
