LukeD |
Member ![]() ![]() Group: Members Posts: 254 Joined: 14-November 04 From: Atascadero, CA Member No.: 3,117 Region Association: None ![]() |
I have a 70 with original calipers, I am going to send them to Eric Shea next week. My question is, I have a 75 parts car and I would like to keep my 70 semi drivable sooooo, can I send the 75 calipers to Eric and then when I get them back will they bolt right on to the 70? Also, Pelican sells those "Speed Bleeder Valves" are they highly recommended?
Or should I invest in one of those $45 power bleeders? Luke D |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,192 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
IIRC they are not identical, however they can be mixed-and-matched with no problems. The only difference I think is that the early has top and bottom bleeder valves while the late only has the top ones. Or I may have that backwards.
Speed bleeders are recommended by a number of people who have them. I haven't installed mine yet... Other folks like the power bleeder. Some sickos probably have both. (At least one really sick person has both speed bleeders and a power bleeder and has yet to use either of them.) --DD |
Rusty |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 7,969 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: South East States ![]() ![]() ![]() |
I have both, and much prefer the speed bleeders. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
-Rusty (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif) |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Early '70-Mid '73....single bleeder top
Late Late '73 - "76.....dual bleeders, but no one has determined the need for the bottom bleeder (maybe flushing the system) Functionality....the same Production rebuilders drill the single bleeders for the bottom bleeder, but they don't really know why. |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,288 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
There are some internal differences also, however they are functionally the same. No problem in mixing the calipers. My belief is that draining the calipers during bleeding is a good idea. Flush fluid from the reservoir to each caliper to ensure fresh fluid is at each caliper. Then drain to get all the old fluid out; otherwise old fluid will remain inside the pistons, particularly on the outboard side. You have to realize that the fluid inlet and bleed nipples are very closely coupled. The fuild will take the shortest path, and that does not include the outer caliper half at all. A simple bleed will never change the fluid in the outer caliper half. The adjuster mechanism in the calipers does an excellent job of trapping old fluid. Only by removing the pistons and rinsing with alcohol can you do a perfect job. Just like stale gas can ruin an engine, so can old fluid ruin a caliper. While this may be critical for racers, a complete job every few years for a street car is adequate. |
LukeD |
Thanks for the great info, I have decided to send Eric the ones off my 75 parts car.
Luke D |
Lo-Fi Version | Time is now: 1st July 2025 - 10:03 AM |
