PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,904 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
Thinking WCR and leaving the car in the parking lot. Anyone have a smart alternative for an alarm?
rmdinmd |
Member ![]() ![]() Group: Members Posts: 489 Joined: 30-October 13 From: Greeneville,Tn Member No.: 16,585 Region Association: South East States ![]() ![]() |
Depends on what it is you want to accomplish. (IMG:style_emoticons/default/biggrin.gif) Basically, I don't leave any thing of real value in car and I have one of the battery connectors that has a quick disconnect that I can remove and in essence disconnects the battery. I can lock the car but a determined thief can always get in (IMG:style_emoticons/default/mad.gif)
GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,628 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
pull the wire from the coil. You can't stop someone that REALLY wants to take your car while it is unattended, but you can slow them down during the process.
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Or take the rotor out of the distributor. Can't reconnect what isn't there.
At an event like WCR where so many fellow enthusiasts are everywhere all the time.... Don't sweat it. |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,735 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
A pet Rattlesnake! (IMG:style_emoticons/default/evilgrin.gif)
toolguy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,276 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California ![]() ![]() |
Add a factory switch, like one for a rear window heater, and wire it into the leads from the ignition to the coil or fuel pump. . Looks stock and will not be able to start unless turned on. engine will crank but no fire. .
Bulldog9 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region ![]() |
Just keep the top off and a bowl of water/food, good to go!
;-) I dont have an alarm for my car (yet) but I did strategically leave the fuse for my fuel pump and starter relay in very accessible locations to discourage any unauthorized starting. Attached image(s) ![]() |
1stworks |
Member ![]() ![]() Group: Members Posts: 491 Joined: 31-March 13 From: colorado Member No.: 15,718 Region Association: None ![]() |
I take my wheel with me if I am somewhere shady.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1315.photobucket.com-15718-1461513093.1.jpg) |
Amphicar770 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,219 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region ![]() ![]() |
Agree that an Alarm will not stop a determined thief. Maybe one of these to help find it after it is gone. They alert you if any movement and provide GPS type tracking.
http://www.findmespot.com/en/index.php?cid=128 |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
I keep my car looking like a POS so they steal yours first. See you at WCR! (IMG:style_emoticons/default/piratenanner.gif)
Alphaogre |
Member ![]() ![]() Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California ![]() |
https://geoskyalert.com
This one runs through an app on your phone, door opens or it moves, you get notified and can track in real time. You can ping it, arm/disarm it and track history or in real time through google maps, all through your phone tablet or computer. It's pretty trick, I have some buddies that use it on their trailers as well. |
Rand |
Bellis for the win. The real trick is the thief won't even know what engine he is steeling. Befuddle is the best defense. =>)
LowBridge |
Member ![]() ![]() Group: Members Posts: 370 Joined: 10-August 15 From: Lunenburg, MA Member No.: 19,045 Region Association: North East States ![]() |
I keep my car looking like a POS so they steal yours first. See you at WCR! (IMG:style_emoticons/default/piratenanner.gif) +1 hahaha |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Just pull the FP fuse or relay if you're worried about someone stealing the car. Park close to your room.
falcor75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia ![]() ![]() |
Another easy trick is to pull the switched 12v cable from the starter motor.
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,934 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
Get a $100 Iphone 4, wire the charger to the car, and toss it in the front trunk. Add it to your service for an extra $10 a month, and if the car goes missing, use Find My Phone service.
After Wayne's car went missing, I guess we need to be working on something like this. |
jd74914 |
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,850 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States ![]() |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,906 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
don't you guys watch TV, parking enforcement can backup lift your car and be gone in a minute....
How about this ? http://www.ebay.com/itm/Wheel-Lock-Clamp-B...%3D182004565523 Attached thumbnail(s) ![]() |
sixnotfour |
this is the best;
http://www.instructables.com/id/Using-Smar...n-Sensor-Alarm/ |
forrestkhaag |
Senior Member ![]() ![]() ![]() Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region ![]() |
None of that works.
So some device makes you aware of a group of armed gangbangers stealing your ride and you do what? Call the cops? To late - He gone.. Confront them with your 12 Gauge Citori? You're headed to court for years and lose your home and 914 to the underprivileged degenerate loser's attorney's fees / The State pays their defense fund as they are not financially able.... (IMG:style_emoticons/default/poke.gif) The thieves that recently stole three 993's in Laguna (and my street legal lifted golf cart) all in a month or two - used a flat bed tow truck and blobs of grease on the tire path up to the bed. Given a tow hook, a locked car, locked steering, set parking brake and gears engaged does not matter one whit.......She Gone! My recommendation is to carry stated value insurance and maintain good current photo documentation to defend the value stated. Haggerty recently called to up my stated value by 15K as they are aware of the values escalating on 914's / I park in the most remote locations when necessary, responsibly lock the car and sleep like a baby......... (IMG:style_emoticons/default/beerchug.gif) http://www.lagunabeachindy.com/auto-thieve...eting-porsches/ (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 6th July 2025 - 11:57 AM |
