Removal of 914-6 Heat Exchangers, How to get the three nuts off? |
Daiberl |
Apr 24 2016, 01:14 PM
Senior Member Group: Members Posts: 574 Joined: 22-June 09 From: Seattle, WA Member No.: 10,497 Region Association: Pacific Northwest |
In the process of removing the HEs from the 2.2 engine, was able to open the Allen fine but there are three bolts (2 passenger side and 1 driver side) at the front cylinders, how to get them off, seems to be impossible to get a ratchet in and my wrenches see to also not fit very well. Afraid I might damage one of the nuts.
toolguy |
Apr 24 2016, 01:29 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
I used 12mm nuts on those. .
I have a couple of wrenches I bent, and a 1/4 drive 12 mm socket will do the trick. . It's a pain in the butt and small hands and long fingers help. . Besides the dash nuts, it's one of the harder places to get to. . The 1/4 inch angle drive thin wall socket is great for getting them snug. . then a bent wrench to tighten fully but it's a 1/6 turn at a time job. . Attached image(s) |
Daiberl |
Apr 24 2016, 01:40 PM
toolguy, thanks, also just figured I posted in the wrong forum, maybe an admin can move it to the garage.
puffinator |
Apr 24 2016, 01:53 PM
Member Group: Members Posts: 193 Joined: 6-August 13 From: Annapolis, MD Member No.: 16,218 Region Association: MidAtlantic Region |
rhodyguy |
Apr 24 2016, 02:29 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
On 4s I use a 1/4" drive and the thinnest wall socket I have. Did you spray the nuts down with penetrating fluid? More than once?
Daiberl |
Apr 24 2016, 03:24 PM
On 4s I use a 1/4" drive and the thinnest wall socket I have. Did you spray the nuts down with penetrating fluid? More than once? Sprayed them more than once, the problem is that they are really hard to reach. Will check to get a flex socket and then we will see. |
flyer86d |
Apr 24 2016, 07:48 PM
Member Group: Members Posts: 429 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
Also, heat them up until they are cherry red and then proceed carefully. If they don't move or stop moving, let them cool and then heat them again. Repeat as necessary.
Charlie |
Daiberl |
Apr 24 2016, 10:15 PM
Done! Got them off, bought the two tools in the picture at Harbor Freight and after soaking them on WD40 for a few hours they got off really smooth.
rgalla9146 |
Apr 25 2016, 07:19 AM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Looks like those boxes were on a an engine with mechanical fuel injection.
rhodyguy |
Apr 25 2016, 07:25 AM
Good eye. How could you tell?
bradtho |
Apr 25 2016, 08:02 AM
Member Group: Members Posts: 266 Joined: 22-December 09 From: Seattle, WA Member No.: 11,165 Region Association: None |
Since you posted this in the classifieds, I'll repeat my offer to buy them from you for $100. (IMG:style_emoticons/default/poke.gif)
mountainroads |
Apr 25 2016, 08:36 AM
Member Group: Members Posts: 210 Joined: 19-February 12 From: Seattle Member No.: 14,145 Region Association: Pacific Northwest |
Daiberl |
Apr 25 2016, 08:53 AM
Good eye. How could you tell? The take-off (at the front) for the MFI pump temp sensor feed. What's interesting to me is these must've been modified at some point to accommodate MFI, since all stock 914-6's came with carbs. - MR Correct, car came with MFI, but will go back to carbs. |
Daiberl |
Apr 25 2016, 08:54 AM
Since you posted this in the classifieds, I'll repeat my offer to buy them from you for $100. (IMG:style_emoticons/default/poke.gif) Let me think about your offer for a sec ...... No, thanks, will keep them (IMG:style_emoticons/default/smile.gif) |
sixnotfour |
Apr 25 2016, 07:25 PM
914 Wizard Group: Members Posts: 10,434 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
$914
Kaeferfreund |
Apr 26 2016, 02:02 PM
Member Group: Members Posts: 122 Joined: 28-July 13 From: Germany Member No.: 16,172 Region Association: Germany |
On 4s I use a 1/4" drive and the thinnest wall socket I have. Did you spray the nuts down with penetrating fluid? More than once? Sprayed them more than once, the problem is that they are really hard to reach. Will check to get a flex socket and then we will see. Hi! You got them off now, but before you sprayed them with WD 40? Hmmm...the best I know is that one: Caramba Rasant Rostlöser/swift shock rust remover: http://www.caramba.eu/en/products/swift-shock-rust-remover/ Nothing which was not to remove with that fantastic spray Darauf ein König (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/smilie_flagge6.gif) |
Daiberl |
Apr 26 2016, 02:29 PM
On 4s I use a 1/4" drive and the thinnest wall socket I have. Did you spray the nuts down with penetrating fluid? More than once? Sprayed them more than once, the problem is that they are really hard to reach. Will check to get a flex socket and then we will see. Hi! You got them off now, but before you sprayed them with WD 40? Hmmm...the best I know is that one: Caramba Rasant Rostlöser/swift shock rust remover: http://www.caramba.eu/en/products/swift-shock-rust-remover/ Nothing which was not to remove with that fantastic spray Darauf ein König (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/smilie_flagge6.gif) Caramba habe ich in Deutschland auch immer benuetzt, gibt es hier aber glaube ich nicht und mit WD40 habe ich ganz gute Erfahrungen gemacht. Darauf ein IPA (IMG:style_emoticons/default/beer3.gif) |
rgalla9146 |
Apr 26 2016, 06:43 PM
Lo-Fi Version | Time is now: 7th June 2024 - 05:08 AM |
