mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,905 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
Is there a difference between front suspension on our cars someone told me the 2.0 front suspension had tabs welded to the a arms? Everything I have seen shows it all the same.
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
I have seen the sway bar u tabs on cars without bars, regardless of engine size. I have also seen sway bars on 1.7 L cars.
Luke M |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,380 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States ![]() ![]() |
Only thing that I'm aware of is the sway bar tabs on the a-arms.
Some 914's had them while others didn't otherwise all the same. There's a difference in 914 early vs late brake systems. Now if you're talking 914 vs 914-6/911 there's a difference in a few areas. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,325 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I believe all early cars had the tabs even if they didn't come with the bars. Unfortunately, you still have to drill for the - through the body mount.
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,570 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Different torsion bar spline count on sixes.
No sway bars as original equip. on a six |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Not sure about that last point. I think that at some point you could order a Six with sway bars? But, as I said, I'm not sure about that.
--DD |
rgalla9146 |
Not sure about that last point. I think that at some point you could order a Six with sway bars? But, as I said, I'm not sure about that. --DD It's purely an observation on my part. I've never seen an option list for a 1970 4 cyl. or 6 cyl. but can't say I've ever looked for one either. Anyone ? Did a 1970 sales brochure list options ? |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,688 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Unfortunately, you still have to drill for the - through the body mount. Or use the 911 style under-body swaybar. I ran one of them for a while and it worked just fine. You need the matching round tabs for the a-arms but other than that, no cutting needed. (IMG:style_emoticons/default/shades.gif) |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,912 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Six's never had factory optioned sway bars. Factory PREPARED sixes for racing did. All cars 1.7, 1.8 and 2.0 had U tab control arms up to 1975. They did some cost cutting by leaving them off. SOME 76 cars DID have U tabs on control arms when they started running out of parts at the end of production.
JFJ914 |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States ![]() ![]() ![]() |
Six's never had factory optioned sway bars. Factory PREPARED sixes for racing did. All cars 1.7, 1.8 and 2.0 had U tab control arms up to 1975. They did some cost cutting by leaving them off. SOME 76 cars DID have U tabs on control arms when they started running out of parts at the end of production. My factory 1974 1.8 arms do not have the tabs. |
914Sixer |
Is your 74 a late in the year model? Like May, June, July?
Lo-Fi Version | Time is now: 17th June 2024 - 09:54 AM |
