Papermaker |
Newbie ![]() Group: Members Posts: 35 Joined: 19-January 04 From: Custer WI. Member No.: 1,578 ![]() |
Hi--
I was told that this muffler is an early 911 muffler or possibly from an 914-6. In either case it is supposed to fit a 911, 914-6 or a conversion 914. Can anyone verify the muffler for me and let me know what it fits? Thanks, --Papermaker ![]() ![]() |
tomrev |
Member ![]() ![]() Group: Members Posts: 231 Joined: 25-February 14 From: N. Mich. Member No.: 17,037 Region Association: None ![]() |
Looks like a Lietritz (maybe spelling is off), and could also be Dansk. I know the Lietritz was factory thru mid-70's on 911's.
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
You need to look for this stamp.
Attached image(s) ![]() |
Papermaker |
Hi Jeffs9146--
I'm from the "It is better to curse the darkness a thousand times than to light a single candle" group. After looking a couple of times I found part number: BISHOFF 911 . 025 . 00 /0577. Can you tell what this is from and will fit? Thanks, --Papermaker ![]() |
Jeffs9146 |
Hi Jeffs9146-- I'm from the "It is better to curse the darkness a thousand times than to light a single candle" group. After looking a couple of times I found part number: BISHOFF 911 . 025 . 00 /0577. Can you tell what this is from and will fit? Thanks, --Papermaker ![]() 1977, 1978 911. The date code is 0577 so it was first installed sometime after that date. It will fit just about anything that was two in one out. You can put it on a 914-6 but the tip will point down low. Some people cut and re-weld the tip to make it fit the rear valance better. |
Papermaker |
Ok Jeff, thanks for the info.
--Papermaker |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Lo-Fi Version | Time is now: 10th June 2024 - 12:05 PM |
