4 barrel carb on rotary 13b (Holley?), Nope....its a heavily ported Nikki carb |
matthepcat |
May 16 2016, 12:37 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
I am a complete noob when it comes to Mazda rotary engines. Having just purchased a 13b conversion car, I am lucky enough to have found this one which runs excellent.
I am 95% sure that this car is running a Holley, but there are no distinguishing markings anywhere on the carburetor. Here are a few pictures: Is this enough for someone out there to say, "yep that's a Holley"? The only strange characteristic of this carburetor is when I aggressively accelerate up to the 9k RPM range, it will sometimes sputter as I let off the gas like it runs out of fuel. I am assuming that this is a problem with the fuel pump being able to provide enough fuel pressure to flow at that RPM. Reading online I see that most of the racing/high performance rotary guys run a fuel surge tank. Could this help cure this issue, or would a slightly higher performance pump with a good fuel pressure regulator cure the fuel starvation problem? I currently run a Carter fuel pump that is probably old. |
ssuperflyoldguy |
May 16 2016, 02:29 PM
Member Group: Members Posts: 173 Joined: 15-November 15 From: NorCal - East Bay Baby! Member No.: 19,364 Region Association: None |
I'm thinking that is part of a fuel injection system.... |
matthepcat |
May 16 2016, 03:28 PM
Mike Bellis |
May 16 2016, 03:36 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
It's definitely special for the rotary. I would run a high flow pump with a return regulator to keep the pressure low enough for the carb.
Wait, I would replace that with a 48 IDA single down draft carb and manifold. I don't think you can go out and buy a new double pumper and get it to work correctly. I will say there is quite a bit of polishing in that top hat. Parts are impossible to come by at your FLAPS. You will need to mail order most of your parts. I used to get a lot from Atkins Rotary. http://atkinsrotary.com/store/ |
Mike Bellis |
May 16 2016, 03:38 PM
matthepcat |
May 16 2016, 04:18 PM
Thanks..lol (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/rolleyes.gif)
I think Mike is the winner winner here. Looks like a heavily modified/ported Nikki carb. (IMG:http://www.914world.com/bbs2/uploads_offsite/i6.photobucket.com-11125-1463437101.1.jpg) |
matthepcat |
May 16 2016, 04:26 PM
I think I am going to run a fuel injection system using somthing like these:
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.borlainduction.com-11125-1463437580.1.jpg) http://www.borlainduction.com/throttle-bod...components.html I will run Megasquirt or there is a simple cheap solution through a company called Ecotrons. http://www.ecotrons.com/products/wankel_en..._injection_kit/ |
Mowog4 |
May 16 2016, 04:27 PM
Member Group: Members Posts: 291 Joined: 2-November 15 From: Mesa AZ Member No.: 19,325 Region Association: None |
i am running a Holley Blue fuel pump knockoff on my Bugeye Sprite with a 13B in it. I am switching to fuel injection in the next few weeks, you are welcome to the pump and regulator if you want it. Send me a pm and I will drop it in the mail. 13B's use a lot of gas, they need enough volume to make it run correctly. Ed
matthepcat |
May 16 2016, 04:29 PM
i am running a Holley Blue fuel pump knockoff on my Bugeye Sprite with a 13B in it. I am switching to fuel injection in the next few weeks, you are welcome to the pump and regulator if you want it. Send me a pm and I will drop it in the mail. 13B's use a lot of gas, they need enough volume to make it run correctly. Ed ^ sweet ^ Pictures please! What are you doing for fuel injection? |
Mowog4 |
May 16 2016, 04:38 PM
I am running a Jenvey Throttle body, racing beat intake, MegaSquirt MS3 Pro, and a Walbro fuel pump. It is sitting in a box waiting for installation. The engine is a large street port. I wired the actuators open and am still using the oil metering pump. I will start on it in a couple of weeks.
matthepcat |
May 16 2016, 04:47 PM
very cool. I would be interested to see your set-up completed.
I have little to no documentation on this engine, but based off its idle I think that it is bridge ported. I like the idea of getting more fuel efficient with FI, and I read you can get a more usable torque curve over carburetor. I am running a Jenvey Throttle body, racing beat intake, MegaSquirt MS3 Pro, and a Walbro fuel pump. It is sitting in a box waiting for installation. The engine is a large street port. I wired the actuators open and am still using the oil metering pump. I will start on it in a couple of weeks. |
Mowog4 |
May 16 2016, 05:07 PM
I will send you some photos when I get it going. There is a very good write up from a guy named Aaron Cake at the rx7 forum about doing a MegaSquirt conversion. It is worth the read.
Mike Bellis |
May 16 2016, 05:22 PM
If you keep the distributor and coils, you can use megasquirt. If you want ignition control you will need to go with a Haltech rotary ECU or similar.
matthepcat |
May 16 2016, 05:57 PM
Mowog4 |
May 16 2016, 07:03 PM
I am doing both ignition and fuel with the MegaSquirt 3 pro. I am using a Full Function Engineering crank drive with the RX 7 coil pack.there is a bunch of data on DIY fuel injection
Mike Bellis |
May 16 2016, 08:10 PM
Mat, I have a crank angle sensor (looks kind of like a distributor) to replace the distributor if you go with ignition timing. I don't think I have any other rotary EFI stuff anymore. I sold it all off. But my blown motor has the crank sensor intact. You can have the blown motor too. Just needs an apex seal.
matthepcat |
May 16 2016, 11:42 PM
Free blown motor! Sweet!
Thanks Mike, at least I can pull it apart and learn about these motors. |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:54 AM |
