Geez...another clutch cable question, How many turns or amount |
BeemerSteve |
May 16 2016, 07:05 PM
Member Group: Members Posts: 239 Joined: 2-September 15 From: Van Zandt, Wa Member No.: 19,123 Region Association: Pacific Northwest |
Yesterday I replaced all my clutch components and now I'm ready to put the cable on. My question would be once I thread the cable up to the pedal cluster end how much do I turn the clevis down on the cable before I connect it to the pedal end?
By the way...on a previous post I wanted to know if it was easier to take the whole lump out or just the transmission. I pulled the transmission only and went out and in without a problem. Thanks in advance all!! |
BeemerSteve |
May 17 2016, 06:39 AM
No one? Can I plead my case? (IMG:style_emoticons/default/sad.gif)
Amphicar770 |
May 17 2016, 07:05 AM
Senior Member Group: Members Posts: 1,197 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
When I did mine, I just went with approximately where it was on the old cable. Do not remember exactly where that was. You are doing adjustment from the rear so I do not think the pedal side matters as much. Maybe someone has a better answer.
BeemerSteve |
May 17 2016, 07:14 AM
When I did mine, I just went with approximately where it was on the old cable. Do not remember exactly where that was. You are doing adjustment from the rear so I do not think the pedal side matters as much. Maybe someone has a better answer. Thanks...that's kinda where I'd begin too if I don't hear otherwise. Thanks again for responding! |
rhodyguy |
May 17 2016, 07:47 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Your Haynes details the specified length for the cable protruding at the Clevis end. Don't know where my manual is right now.
Mikey914 |
May 17 2016, 01:31 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Would be about where the old cable was if it didn't stretch and break. Make sure you install the ground back at the transmission, otherwise your clutch cable will be the net route for ground and the cable will appear to stretch, and snap. The best way to adjust is to drive it, and adjust as necessary to get the release point where you want it. You'll know real quick where it needs to go.
BeemerSteve |
May 17 2016, 01:59 PM
Would be about where the old cable was if it didn't stretch and break. Make sure you install the ground back at the transmission, otherwise your clutch cable will be the net route for ground and the cable will appear to stretch, and snap. The best way to adjust is to drive it, and adjust as necessary to get the release point where you want it. You'll know real quick where it needs to go. Thanks you very much for the info Mark...it's much appreciated as I should now invest in a manual. I'm now convinced too! (IMG:style_emoticons/default/biggrin.gif) |
0396 |
May 17 2016, 02:04 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Lo-Fi Version | Time is now: 9th June 2024 - 07:35 PM |
