FS:drilled 5-bolt rear hubs |
914forme |
May 29 2016, 07:23 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
A set of drilled 5 bolt rear hubs, I don't need these for my project anymore.
$50 shipped in the cont. US of A |
bdstone914 |
May 29 2016, 07:32 PM
bdstone914 Group: Members Posts: 4,524 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Interested but what are the marks on the back side around the drilled holes? Looks like gound off welds. What are the hole diameters? Studs vary by brand and I want 5o make sure they are not oversized for Veribus studs.
Thanks |
ssuperflyoldguy |
May 29 2016, 11:35 PM
Member Group: Members Posts: 173 Joined: 15-November 15 From: NorCal - East Bay Baby! Member No.: 19,364 Region Association: None |
Pm sent
914forme |
May 30 2016, 03:16 AM
Interested but what are the marks on the back side around the drilled holes? Looks like gound off welds. What are the hole diameters? Studs vary by brand and I want 5o make sure they are not oversized for Veribus studs. Thanks Tacked on some of the studs, I use a set from CB Performance, and the constant on off for auto-x, I spun one with my impact. I only use the cordless impact to take them off BTW, everything goes on by hand, well with a cordless drill, then torques to spec. Had to drive home on race rubber in the rain. No fun, so for insurance purposes I tacked them. Never had an issue after that. CB Performance Studs 0.58" = 14.732mm Did not know you could get larger studs than these, makes sense never looked into it. |
914forme |
May 30 2016, 03:21 AM
sael pending
bdstone914 |
May 30 2016, 07:19 AM
Interested but what are the marks on the back side around the drilled holes? Looks like gound off welds. What are the hole diameters? Studs vary by brand and I want 5o make sure they are not oversized for Veribus studs. Thanks Tacked on some of the studs, I use a set from CB Performance, and the constant on off for auto-x, I spun one with my impact. I only use the cordless impact to take them off BTW, everything goes on by hand, well with a cordless drill, then torques to spec. Had to drive home on race rubber in the rain. No fun, so for insurance purposes I tacked them. Never had an issue after that. CB Performance Studs 0.58" = 14.732mm Did not know you could get larger studs than these, makes sense never looked into it. Thanks for the reply. That tells the stud dimension only to + or - .010" not the hole size. Studs have a slight size variation my manufacturer. Glad I did not get them as it sounds like the holes are slightly oversize allowing a stud to spin. Good luck to the new owner. |
914forme |
May 30 2016, 09:18 AM
So what size are the holes supposed to be?
BTW FAT did them back in the day. Doubt they did all of them oversized. |
bdstone914 |
May 30 2016, 07:05 PM
Lo-Fi Version | Time is now: 22nd May 2024 - 10:40 PM |
