Valve Noise, TAP TAP TAP TAP |
zeekman914 |
Apr 7 2005, 01:39 PM
Member Group: Members Posts: 67 Joined: 1-December 04 From: Arcata, CA Member No.: 3,202 |
Same as always my friend has a VW Bug that is converted to a Baja. It has a stock 1600 with a single solex carb and dual ports. It's exhaust is straight-piped. Anyway we tightened up the rocker to valve stem clearence because the engine was making a tap tap tap noise as it was running on the driver side bank. After tightening them up we started the engine and the noise was even louder. We listened to it with stethascopes( you know the ones for cars) and the noise could be heard on the side of the cylinders, pushrod tubes and the valve cover. Whats wrong?
Thanks Z (IMG:http://www.914world.com/bbs2/html/emoticons/nuke.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/crest.gif) |
Joseph Mills |
Apr 7 2005, 02:10 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
I would suggest first that you read the thread by The Capt'n posted recently for valve adjustments. Extremely informative.
Then go back and re-check your settings. Hopefully, that will get your there. If it persists, you may have other issues. Keep posting questions and you will get answers. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
nebreitling |
Apr 7 2005, 03:31 PM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
dude, put down the tools and step away from the car...
go get a manual. look up the spec valve clearances. adjust to spec. a little "tick-tick-tick-tick-tick-tick" is normal. |
Aaron Cox |
Apr 7 2005, 03:35 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
uh.. did you adjust them with the valves closed??? (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
TheCabinetmaker |
Apr 7 2005, 03:47 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I don't mean to imply anything, but is this your first VW valve adjust? Wrongly adjusted valves can cause major engine damage. Please tell us what you did?
zeekman914 |
Apr 7 2005, 06:21 PM
Yes it is my first adjustment. My friend got a book for a 1200 thinking that a 1200 and a 1600 would be the same setup. WRONG! So lukeily the valves are just a tad looser. I will go tell him to take it easy.
TheCabinetmaker |
Apr 7 2005, 06:31 PM
I'm not that well versed on type I's, but it "should" be the same for 1200 0r 1600.
Go here and read it 5 times. If it still doesn't make sense, get someone to do it and let you observe. Pricless! http://www.914world.com/bbs2/index.php?act=...=ST&f=2&t=28758 Best Regards and Good Luck! |
Dave_Darling |
Apr 7 2005, 06:43 PM
I have found that the "feel" is not that easy to describe. I read and read and read, and the first time I did a valve adjust I got all of the valves way too loose. (Old Honda Accord, thankfully--I wasn't about to try it first on my 914!!!) So a buddy who has done valve adjusts stopped by, and got one set for me. I checked it after he was done, and that gave me the "feel" for just how tight the valve and adjuster should be on the feeler gauge.
...I haven't killed any motors yet... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Anyway, that's what I suggest you do. Get someone who knows how to adjust valves over, and have them set one for you. Then you check it, and see how the gauge feels in the gap. --DD |
TheCabinetmaker |
Apr 7 2005, 06:45 PM
whew!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
Dave_Darling |
Apr 7 2005, 06:58 PM
Well, I did bend a pushrod in Jan Mayo's car at the last MUSR. And Yoder still hasn't forgiven me for that 1st-R "upshift" at one of the previous MUSRs... But those were my "driving" technique, not from working on the car... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
--DD |
Trekkor |
Apr 7 2005, 07:18 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
Aren't all the air cooler's set at .006?
KT Attached image(s) |
Lo-Fi Version | Time is now: 3rd June 2024 - 11:07 AM |
