| tjtryon |
Jun 25 2016, 07:57 PM
Newbie ![]() Group: Members Posts: 20 Joined: 15-June 16 From: Indianapolis Member No.: 20,112 Region Association: None |
I have a 1973 Porsche 914 2.0L (4x130 wheel bolt pattern).
I am thinking I can get a set of wheel adapters to change it to 5 x 130, a set of 5 lug Fuchs Replicas (http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-6649) - with 5 inches backspacing and 205 width tires. Does anyone with a stock fendered 914 run this combo? Any chance it will work with 205 width tires? Car will see street use - no track or autox at this time, so the adapters should handle the load without issues. Many thanks in advance for the info! |
| JRust |
Jun 25 2016, 09:16 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest
I have a 1973 Porsche 914 2.0L (4x130 wheel bolt pattern). I am thinking I can get a set of wheel adapters to change it to 5 x 130, a set of 5 lug Fuchs Replicas (http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-6649) - with 5 inches backspacing and 205 width tires. Does anyone with a stock fendered 914 run this combo? Any chance it will work with 205 width tires? Car will see street use - no track or autox at this time, so the adapters should handle the load without issues. Many thanks in advance for the info! No it won't work. Those 4-5 lug adapters are crap. For mild street use it might be okay. They still would not fit. The adapters add an inch. So such replica's would not work. You might get later offset 911 wheels to work. Having said all that. If you want to go 5-lug do it right. You can do it reasonable using all your stock 4-lug parts & drilling. |
| mepstein |
Jun 25 2016, 09:27 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,924 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I have a 1973 Porsche 914 2.0L (4x130 wheel bolt pattern). I am thinking I can get a set of wheel adapters to change it to 5 x 130, a set of 5 lug Fuchs Replicas (http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-6649) - with 5 inches backspacing and 205 width tires. Does anyone with a stock fendered 914 run this combo? Any chance it will work with 205 width tires? Car will see street use - no track or autox at this time, so the adapters should handle the load without issues. Many thanks in advance for the info! No it won't work. Those 4-5 lug adapters are crap. For mild street use it might be okay. They still would not fit. The adapters add an inch. So such replica's would not work. You might get later offset 911 wheels to work. Having said all that. If you want to go 5-lug do it right. You can do it reasonable using all your stock 4-lug parts & drilling. (IMG:style_emoticons/default/agree.gif) |
| Mueller |
Jun 25 2016, 09:40 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
I don't think they will fit, they will still hit I believe. If looking at those $50 adapters those look like the cheap cast I got on a parts car once. I promptly cut those up on my band saw so as to not let anyone else I know run them!
Not hard to test it, just use your current wheels to mock it up using the numbers you supplied. or plug the numbers into this: http://www.willtheyfit.com/ |
Lo-Fi Version | Time is now: 6th October 2026 - 07:28 PM |
