1974 2.0 fuel pump, Looking for suggestions on replacing a 1974 2.0 fuel pump. |
taylordm@att.net |
Jul 14 2016, 10:32 AM
Newbie Group: Members Posts: 8 Joined: 5-May 09 From: Blue Springs Missouri Member No.: 10,333 Region Association: Upper MidWest |
Looking for suggestions on replacing a 1974 2.0 fuel pump. Not wanting to invest 400.00-600.00 on a fuel pump, looking for a good performing replacement.
Dave_Darling |
Jul 14 2016, 05:21 PM
Basically, anything that delivers the right pressure and volume, and has the correct sized fittings, will work fine. With most of them, you will have to eliminate the branch that goes to the "R" fitting on the pump, but that's pretty easy to do. You may also have to get a bit creative with the electrical connection.
--DD |
Lowsquire |
Jul 14 2016, 06:48 PM
Newbie Group: Members Posts: 20 Joined: 23-April 16 From: Austin Texas Member No.: 19,926 Region Association: Southwest Region |
Bosch 69133. easy to find, cheap.(about $70 ) smaller diameter than original, just wrap a piece of rubber inside the clamp to take up the gap.
PlantMan |
Jul 14 2016, 06:52 PM
Member Group: Members Posts: 438 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California |
Airtek which you can get off Amazon for around $65.
Recently installed one in my 74 too. I added a fuel gauge to the fuel rail as well. Purchased everything for under $100. |
Lo-Fi Version | Time is now: 9th June 2024 - 05:01 PM |
