DblDog |
Member ![]() ![]() Group: Members Posts: 164 Joined: 8-February 05 From: San Rafael, CA Member No.: 3,578 Region Association: Northern California ![]() |
OK...the piece of rubber trim between the rear window and the engine lid...is there something I'm missing...its seems like it should just push on, which I did but it won't stay put. Also the window is in place and I don't really want to remove it...help! Thankx
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
keep pushing it in - it will go and you don't need to remove your window. A pair of pliers may help get it seated. Good luck!
914GT |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region ![]() |
If you have the repro rubber piece it does not seem to grip the edge well. You can run a small bead of 3M weatherstrip adhesive into the seal and push it on and that will help hold it in place.
Lo-Fi Version | Time is now: 16th June 2024 - 10:52 PM |
