Little update on my car, Almost got it running tonight |
nebreitling |
Apr 10 2005, 09:34 PM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
yes, i actually own a 914, which might be hard to imagine based on my random mostly-OT-posts the past few months...
it's hard making any progress on it in just random chunks of a few hours here and there, but now i've got a fresh hi-comp 2056 installed and looking damn fine. hooked up all the wiring tonight and cranked it. oil-light went off in about 30 seconds. sounded good and clean. added fuel and spark, got a few pops. one of the IDF's isn't squirting -- ill have to look into that tomorrow. BUT, i'm thrilled to have made it this far. hope to get running tomorrow, align the shifter, install the 5-point harness i've got lying around here, and put some serious miles on it this week. i should be humble about my mechanical abilities, but it's a great sense of accomplishment to put a car back together. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) nathan |
Trekkor |
Apr 10 2005, 09:42 PM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
Yessssss!
Good work, yes, good. (IMG:http://www.914world.com/bbs2/html/emoticons/boldblue.gif) Are you drivin' up thissa way? KT |
nebreitling |
Apr 10 2005, 09:49 PM
probably not till next weekend (but i'll most likely tow anyway). i'd like to put 200 miles on it this week, before the Zone event. which means a lot of driving and tuning, and driving and checking and adjusting valves and such... |
Trekkor |
Apr 10 2005, 10:07 PM
You're gonna love the a/x track at Santa Rosa.
Really good. This place: KT Attached image(s) |
Jeroen |
Apr 11 2005, 04:35 AM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Nathan, good to hear of your progress! Keep us posted/updated when you get it running!
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) And Trekkor is right... Santa Rosa is a fun course (I didn't get lost there (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)) |
rhodyguy |
Apr 11 2005, 08:38 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,092 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
you can bend those carbs to your will. quick test, with engine not running and the filters off, just open the thottle plates and check for the stream of fuel coming from the pump jets. you'll get them nathan. if i can sort out those pesky buggers, anyone can. when you get it running and one of the idle air mixture screws has no effect when you turn it all the way in, pull the idle jet, and the main jet stack on that barrel. blow out the jet and the passage way the jet seats into. i use those cans of compressed air with the long skinny spray tips, stick the tip way into the passage way. if you use a compressor turn the air pressure way down low. fuel will spray out of the main jet hole and hopefully any crap with it.
k |
mike_the_man |
Apr 11 2005, 09:34 AM
I like stuff! Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
Way to go Nate! I look forward to seeing this beast at the WCC. I'm expecting a ride.
Britain Smith |
Apr 11 2005, 12:50 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Looking good Nathan...you need to drive over to my place one night this week. I wanna check it out and you can see what I got in the works. I am about to post and update thread on my car, check it out.
-Britian |
Lo-Fi Version | Time is now: 8th June 2024 - 12:06 PM |
