Help, Dumb Oil Thermostat Question |
PorscheTom |
Apr 11 2005, 10:36 AM
Will work for an Avatar. Group: Members Posts: 140 Joined: 12-May 04 From: Shingletown, CA Member No.: 2,057 |
Hello all,
I've never installed one of these, so I have a dumb noobie question... (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) When a remote oil thermostat is closed, oil that is currently being pumped into it...does it return back to the engine or is it just stopped at the thermostat until it reaches it's opening temp? In other words, when cold, does oil go thru the thermostat and back to the engine - make a loop...? Thanks for any info! |
ArtechnikA |
Apr 11 2005, 10:49 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
yes. it always makes a loop. it's either a short loop that bypasses the cooler or a long loop that includes it. |
dmenche914 |
Apr 11 2005, 12:14 PM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
Generally the cooler is in a loop, and the thermostat bypasses the cooler when cold. (many oil thermostats are two way valves, one inlet, and two outlets, selection on which outlet (or varied amount of each outlet) is dependant on the temperature)
Do not let a cooler get cold oil, cause it could rupture as cold oil can reach very high pressures if taken right off the pump. If you fit the oil cooler in place of the stock cooler (ie use the stock cooler inlet and outlet ports on the engine) the engine already has a pressure relief system to bypass the cooler when things are cold. This regulates the pressure so the cooler won't leak under high start up pressures. On an external cooler, you will likely have more cooling capacity, so a thermostat is required to prevent over cooling the oil, hence you run at an optimal oil temp. The external thermostat is required on aftermarket systems that bypass the stock pressure relief system, and is nice to have even on external coolers that are using the stock pressure relief system, as they go futher, and better control oil temp. |
StratPlayer |
Apr 11 2005, 12:17 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
This is where I mounted my thermostat, cooler is up front
Attached thumbnail(s) |
Aaron Cox |
Apr 11 2005, 12:21 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
what size lines?
Lo-Fi Version | Time is now: 3rd June 2024 - 11:10 AM |
