hold down clap for coil, petronix |
hndyhrr |
Aug 4 2016, 12:49 PM
Senior Member Group: Members Posts: 555 Joined: 1-September 13 From: central point,oregon Member No.: 16,332 Region Association: Pacific Northwest |
The clamp that is original to car is to big for the petronix coil. Can't find smaller one at parts stores and don't want to wait for one to come in the mail.
So the question is what can i use to shim the old one? i was thinking a piece of bicycle tube. |
76-914 |
Aug 4 2016, 01:11 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Sure can
76-914 |
Aug 4 2016, 01:12 PM
Sure can
Mark Henry |
Aug 4 2016, 04:30 PM
I'd only put the pertronix high vibration coil on it's side in the stock location.
The pertronix coils from what I see are MSD coils. Many of the 911 guys have had the MSD oil filled coils leak and then fail, when mounted on the engine. I'd mount an oil filled on the firewall right side up. For the high vibration coil in the stock location I'd cut a bit out of the clamp down close to the one end, bend and weld it back together. |
Dave_Darling |
Aug 4 2016, 04:31 PM
A piece of bicycle inner tube is exactly what I used on my Bosch Blue coil, which is also too small for the stock bracket.
--DD |
914Sixer |
Aug 5 2016, 05:27 AM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
If you have a spare rear blower motor pad that will work too.
worn |
Aug 5 2016, 06:08 AM
can't remember Group: Members Posts: 3,163 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I'd only put the pertronix high vibration coil on it's side in the stock location. The pertronix coils from what I see are MSD coils. Many of the 911 guys have had the MSD oil filled coils leak and then fail, when mounted on the engine. I'd mount an oil filled on the firewall right side up. For the high vibration coil in the stock location I'd cut a bit out of the clamp down close to the one end, bend and weld it back together. So I discovered. Switched to MSD in epoxy. Hope it holds. |
Lo-Fi Version | Time is now: 8th June 2024 - 02:27 AM |
